Old 08-31-2009, 02:04 PM   #1
Wash basin in Garage Drainage Question
My wash basin's drain pipes in the garage is ABS plastic then clamped with sleaves to a metal pipe through the wall, then I believe back to abs underneath the house.
Is this code? Can I go with abs through the wall?
Also it's got an exhaust vent through the wall and a P-trap, does it need both?
amdspitfire is offline   Reply With Quote
Old 09-02-2009, 05:04 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
I'm not a pro plumber, but the answers to all three of your questions are yes.
Mike
Mike Swearingen is offline   Reply With Quote
Old 09-05-2009, 03:51 PM   #3
bump for another response, it would be easier to go straight ABS through the wall
Old 09-06-2009, 07:54 AM   #4
JDC
Plumbing Contractor
JDC's Avatar
Yes, you can go through through a wall with ABS. In certain situations we put in a sleeve for the pipe to go through (ie concrete walls, block walls, foundation walls, etc). If its just a drywalled stud wall then no sleeve is really necessary.
Yes, you do need a vent. This allows air into the plumbing system. Ever hold your finger over the end of a straw and try to get coca-cola to drain out?
Yes, you do need a p-trap. This keeps sewer gases out of your dwelling. If you didnt have one you'd swear "it smells like open @$$ in here!"
So, like Mike said, "Yes to all three"
JDC is offline   Reply With Quote
new double garage murray1426 Building & Construction 4 05-23-2009 02:11 PM
garage insulation question bigbrad123 Building & Construction 4 05-21-2006 01:50 PM
Garage Door Question JOAT General Discussion 4 04-12-2006 10:36 PM
drainage question mwhite Plumbing 2 08-31-2005 12:44 AM
