-   -   Wash basin in Garage Drainage Question (http://www.diychatroom.com/f7/wash-basin-garage-drainage-question-52049/)
amdspitfire 08-31-2009 01:04 PM
My wash basin's drain pipes in the garage is ABS plastic then clamped with sleaves to a metal pipe through the wall, then I believe back to abs underneath the house.
Is this code? Can I go with abs through the wall?
Also it's got an exhaust vent through the wall and a P-trap, does it need both?
Mike Swearingen 09-02-2009 04:04 AM
I'm not a pro plumber, but the answers to all three of your questions are yes.
Mike
amdspitfire 09-05-2009 02:51 PM
bump for another response, it would be easier to go straight ABS through the wall :)
JDC 09-06-2009 06:54 AM
Yes, you can go through through a wall with ABS. In certain situations we put in a sleeve for the pipe to go through (ie concrete walls, block walls, foundation walls, etc). If its just a drywalled stud wall then no sleeve is really necessary.
Yes, you do need a vent. This allows air into the plumbing system. Ever hold your finger over the end of a straw and try to get coca-cola to drain out?
Yes, you do need a p-trap. This keeps sewer gases out of your dwelling. If you didnt have one you'd swear "it smells like open @$$ in here!"
So, like Mike said, "Yes to all three"
