Warm Water In Cold Water Tank - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-18-2009, 08:18 AM   #1
lara1234
Warm water in cold water tank
My brother went up into my loft the other day, and noticed that there was some warm water in the cold water storage tank. Why would that be?
lara1234 is offline   Reply With Quote
Old 12-18-2009, 08:35 AM   #2
Remodeling Contractor
Ambient temperature of the room?
Old 12-18-2009, 08:41 AM   #3
47_47's Avatar
Rewards Points: 44
You could have a faucet that is internally bypassing allowing hot and cold water to mix.
47_47 is offline   Reply With Quote
Old 12-18-2009, 02:56 PM   #4
Registered User
Rewards Points: 5,216
Thermal expansion: http://www.ci.snoqualmie.wa.us/Depar...9/Default.aspx
http://www.watts.com/pro/divisions/w...sp#generalinfo
Be safe, Gary
Old 12-18-2009, 04:11 PM   #5
lara1234
Thanks for the replies. The temperature of the loft is about 45F at the moment as its cold outside and the ceiling joists are insulated making it cold up there. What is a faucet?
Old 12-18-2009, 04:13 PM   #6
What is a faucet?
Must be an American term for that devise on the sink that turn the water on and off.
Old 12-18-2009, 05:15 PM   #7
Rewards Points: 582
You need to get your immersion stat checked, and read this.
http://news.bbc.co.uk/1/hi/england/somerset/7179092.stm
stuart45 is offline   Reply With Quote
Old 12-18-2009, 07:59 PM   #8
Registered User
Thank you for that information, Stuart45!
Be safe, Gary
Water Heater - Water reversed, hot is cold, cold is hot acaciaavenue Plumbing 5 12-09-2009 12:00 PM
Hot water in cold faucets Thurman Plumbing 7 09-20-2009 10:13 AM
Is my Hot Water tank Going K.M.G Plumbing 15 09-02-2009 06:35 PM
Nightmare water tank job Marvin Gardens Plumbing 6 11-04-2008 12:09 PM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 12:19 PM
