Wanting To Replace Gas Lines Under House. - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-17-2009, 08:49 PM   #1
Wanting to replace gas lines under house.
I have a 40+ year old house and wanting to replace the gas lines. I will be calling a plumber to do the job, but wanted info on what materials will be suggested/ offered, pipe, flex, etc. there is about 2.5 foot of crawl space, not too tight, but not the most comfortable to crawl around in.
From the meter goes under the house, the first 20 feet is straight galvanized pipe laying on the ground (mud). One spot is pretty corroded and that's my main concern.
Comes up to the stove and 5 feet further up to the hot water heater. From there it runs to the back of the house to the furnace using copper tubing. The copper tubing is my second concern because I've read that the gas can affect the copper over time.
Sometime before winter, I would like to add a standby generator so new gas lines are the first step, informing the plumber to add a "Tee" for new addition.
So about 50 or so feet of material to stove, hot water heater, furnace, and tee for future generator. Is this a one day job? What materials? Any advise?
Thanks,
Kevin
Thermographer is offline   Reply With Quote
Old 06-17-2009, 09:27 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
50ft with only three appliances is to me a one day job depending on lay out and how much mud there is. Make sure to rpessure test..20 psi for 30mins
Old 06-18-2009, 01:11 AM   #3
master plumber
cincy plumber's Avatar
I am going to make a suggestion but you have to be certified to install
this product Trac-pipe.
cincy plumber is offline   Reply With Quote
Old 06-18-2009, 02:30 AM   #4
Thanks, I'll be sure to ask.
Old 06-18-2009, 10:30 AM   #5
HVAC / Plumbing
This is easy to run... I don't care for it as it is thin walled & fittings are expensive... Pex is out of the question. Small runs of copper is ok.. Most houses in my area are piped entirely with copper
kenmac is offline   Reply With Quote
Old 06-18-2009, 10:42 AM   #6
master plumber
Trac-pipe is for N/G.www.omegaflex.com/trac.
The O/P was asking about gas line installation.
Old 06-18-2009, 12:57 PM   #7
HVAC / Plumbing
I know he's using gas... Mostlikely ng... I said trac- pipe is thin & fittings are expensive.. Mfg. suggest & the code here requirs it to be grounded... I mentioned about pex being out of the question because I had mistaken the word flex for pex
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
Hello. I moved my house... shtoink Introductions 10 06-25-2008 01:40 PM
"New: House, and need some advise... dcd22 General DIY Discussions 9 06-17-2008 07:12 AM
What to plug sink, toilet lines with, No Shut off valve for house? twilightcall Plumbing 4 05-14-2008 02:02 PM
Will my house make my kids sick??? jokrupinski General DIY Discussions 18 09-29-2006 04:05 AM
