Want To Run New PEX Lines But Manifold Is Full - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-28-2011, 06:30 PM   #1
Rewards Points: 518
Want to run new PEX lines but manifold is full
I'm in a brand new house that has all PEX lines on both the hot and cold side. The manifolds for both hot and cold are copper. The hot side has two spare ports but the cold side is completely full.
I want to install a sink in the basement. Can I simply just "T" off of one of the existing cold PEX lines? If so, do I have to worry about pressure decrease and is there any particular lines I should avoid "T"ing off of?
n0c7 is offline   Reply With Quote
Old 11-28-2011, 06:47 PM   #2
biggles's Avatar
you could T off any cold line...if you could add a brass T into the header for say the bathroom upstairs then reconnect it onto the run and the new cold onto the BULL.that will eliminate any cutting of lines...pressure wise for all you use a sink down there the pressure is always there if the reast of the show is closed not being used,then you'll have regular pressure...
Old 11-30-2011, 11:06 AM   #3
Rewards Points: 518
So are you saying to solder on a T right onto one of the "bulls" then connect the two lines OR cut the line for the sink upstairs just a couple of inches above the bull and then insert the T into the short line then reconnect the sink and new line to the remaining openings on the T?
Low point in water supply lines dave11 Plumbing 3 02-01-2011 08:13 PM
Will water lines freeze if placed behind insulated stud wall in basement? jpsmith Remodeling 22 03-05-2009 01:23 PM
Finding Property Lines kypper Landscaping & Lawn Care 18 08-07-2008 05:18 PM
Grinding stump but how deep are gas and electric lines buried? jbk Landscaping & Lawn Care 1 08-02-2008 12:46 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
