Wall-mounted Sink Has Become Slightly Detached From The Wall - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-16-2013, 03:12 PM   #16
Originally Posted by jagans View Post
put in a Vanity and a new sink and fixture.
If I had more time, money, and we were going to be staying in this house for a while, I'd consider it. But I don't want to do all that work (I wouldn't even have the time) for a project like that.
kevind is offline   Reply With Quote
Old 02-16-2013, 04:18 PM   #17
bbo
put in a Vanity and a new sink and fixture. It looks like that one came out before power steering.
that's modern. I remember ones that had separate spouts for hot and cold.
made washing your hands an adventure.
like this
bbo is offline   Reply With Quote
Old 02-16-2013, 05:32 PM   #18
747
registered
747's Avatar
Rewards Points: 534
I agree. Go to your home improvement center. Grab a vanity and top you can afford and install with faucet. Its the easiest fix. Best of all it will hide alot of the wall there.
747 is offline   Reply With Quote
Old 02-19-2013, 01:37 PM   #19
Building tradesman
different approach
Go to your steel supply and have them cut yo a piece of 1/4 inch steel plate. Chisel a recess across 3 studs(33 1/2) wide and anchor to studs flush.
Did anyone ask if the bracket was still tight to the wall ? Often the angled portion of the bracket will angle just a little bit more from use as a staircase or workbench.
Where was I, Oh yeah, test fit your plate then remove it after outlining the bracket fastener holes. Bring it to your bench and use drill press, or if not so equipped hand drill to drill holes and tap for 1/4 20 bolts. Install bracket when fitting drywall, use a few pieces of 1/4 inch all thread to locate the penetrations through the rock. Perfect time to add a GFI on a dedicated circuit as required by code, maybe redo the leaky tailpiece on the outlet of the sink where it has rusted over time. After finishing, use hex bolts, fender washers, flat washers and lockwshers for the bracket. .
BUT DO CHECK TO SEE IF MAYBE THE BRACKET WAS TWEAKED, as afterall, it is February and don't know about you but I am at my winter post holiday need to get moving weight.
dudleydoright is offline   Reply With Quote
2" pipe on above sink in wall rusted out in a spot bryanp22 Plumbing 9 02-23-2012 09:29 PM
wall prep for wall mounted space heater mary574 HVAC 5 11-15-2011 05:11 PM
Trouble with staggered wall rightit Building & Construction 2 03-09-2011 07:23 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Wall mounted scart / aerial socket miked Electrical 5 01-05-2007 06:40 PM
