Wall Faucett - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-14-2008, 03:50 PM   #1
motivator
Speedball's Avatar
Wall faucett
Just thinking ahead about how we will finish our kitchen I was wondering if it would be a problem to mount a wall faucet on an exterior wall?
The use of a farm type apron sink may require such a faucet and being on an exterior wall and the winter temps getting below zero I was concerned about the pipes freezing.
Is it OK to do this or am I asking for trouble?
Thanks Gentlemen.........Pat
............Enjoy...Pat
Speedball is offline   Reply With Quote
Old 12-14-2008, 04:05 PM   #2
Whatamess
Get a 12" frost less and make sure it slopes a little and you will have no problems. Remove the hose if connected in the winter.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 12-14-2008, 05:12 PM   #3
Registered User
Termite's Avatar
TazinCR's interpreting your question to mean an exterior hose bib.
For a kitchen faucet, no it isn't a good idea to have it mounted in the exterior wall if you're in a climate that goes below freezing. Normally the faucet would be mounted in the countertop, which allows the supply lines to be on the warm side of the wall. I would avoid doing what you're proposing at all costs.
Old 12-14-2008, 05:24 PM   #4
Long-Time DIYer
Mike Swearingen's Avatar
The termite is right again as usual
If possible, never install supply pipes in an exterior wall.
If you install it on the sink however, you can always open the base cabinet doors to prevent it from freezing.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 12-14-2008, 07:00 PM   #5
Custom Cabinet Maker
run up thru the floor into the cabinet, 1/4 turn ball stops and flex from there. You can wall mount that style faucet with just a tad of imagination. You have to stay on the warm side of the wall.
skymaster is offline   Reply With Quote
Old 12-14-2008, 07:11 PM   #6
Been there a couple times with the pipes in the wall, not the faucet though, This house they are run up throught the cabinet floor from the basement. Nothing like thawing pipes first thing in the morning when trying to get ready for work. There are ways to deal with it , leave cabinet door open, dog loves that one,, leave the faucet dripping some, but why go through the trouble if you can avoid it. And I know it didn't help that at the time the pipes were in the wall, it was a crawl space under neath.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
Old 12-14-2008, 10:04 PM   #7
Registered User
Termite's Avatar
Thanks Mike. My wife may wish to contest that statement however.
Old 12-15-2008, 06:28 PM   #8
motivator
Speedball's Avatar
Argh... I was afraid of that. Thanks-
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 09:18 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
