Walkup Basement Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-01-2012, 06:06 AM   #1
walkup basement drain
I have a little water in the drain pipe for the walkup basement drain. is that normal or is the pipe clogged? the drain is at the bottom of the steps from basement door up to ground level. should I snake it?
route is offline   Reply With Quote
Old 06-01-2012, 06:09 AM   #2
DIY staff
Rewards Points: 7,174
There is a P-trap at that drain--so some water will always be there (or should be to keep sewer gas from escaping)
Run some water down that drain--if it flows nicely and the water level in the pipe returns to the same level--you are fine--
Old 06-01-2012, 06:18 AM   #3
thanks. I just never noticed water in that drain before. Its usually dry. we are supposed to get a soaker tonight.
Old 06-01-2012, 06:19 AM   #4
one more question. the house is 5 years old. do you think the drain goes to the sump or goes to a french drain?
Old 06-01-2012, 06:35 AM   #5
DIY staff
Typically it will have its own pipe right to the pit---but not always--
The P-traps will dry out during long periods of no rain--
Old Basement Sink Drain - Clay? maybere Plumbing 7 09-27-2011 11:49 AM
Basement vapor barrier over mirror drain eubarch Plumbing 0 09-27-2011 09:57 AM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 10:52 PM
Backed up basement floor drain billvasko Plumbing 2 02-06-2008 01:09 PM
How to drain a utility sink that is in basement? Mikey Palmice Plumbing 40 01-28-2008 09:11 PM
