Walk-in Shower Frame Installed Correctly? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-11-2010, 10:17 PM   #1
Walk-in shower frame installed correctly?
Our house is a couple years old and the master bathroom has a walk in shower. I decided to re-caulk because of a bit of discolor around the edges and noticed that the inside of the bottom frame has these holes in it, like slots or notches (see photo). Was the frame installed backwards? I'm assuming moisture gets in there easily as it was a big gunky.
I know little about installing showers but this seemed odd to me. Is it something to worry about?
drpcken is offline   Reply With Quote
Old 03-12-2010, 01:48 AM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
You're talking about the DOOR frame? Your title is confusing. I wasn't sure what I was looking at initially.
I believe those are weep holes to allow any moisture that might get inside of the frame to escape. I don't install shower doors, so somebody correct me if i'm wrong.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
Snav (03-12-2010)
Old 03-12-2010, 09:03 AM   #3
Sorry for the confusion. Yes that is the door frame facing the inside of the shower.
Old 03-12-2010, 09:20 AM   #4
Military Mom of 4
Snav's Avatar
Yeah, they're weep holes - different construction methods necessitate them. Don't fill them with caulking
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
The Following User Says Thank You to Snav For This Useful Post:
drpcken (03-23-2010)
Old 03-12-2010, 06:07 PM   #5
Wood Butcher
eagle09tbl's Avatar
Mine is exactly the same as yours. They do allow gunk to build up in them from time to time, and about the only thing I have found that helps when cleaning them is to use an old toothbrush.
Nothing to worry about...just a pain to keep cleaned out.
eagle09tbl is offline   Reply With Quote
Recaulking at previously silicone-caulked shower door frame hffeagan Kitchen & Bath Remodeling 36 02-24-2016 03:01 PM
Kitchen Faucet + shower diverter: Need help xtrips Plumbing 1 02-14-2010 04:27 PM
Shower door frame repair? Kennybob General DIY Discussions 1 02-07-2010 02:57 PM
Where "exactly" does the shower pan Membrane go? remodelin'girl Plumbing 1 01-16-2010 06:22 PM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 01:31 PM
