Walk-in Shower, Cutting Waste Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-23-2012, 03:35 PM   #1
Walk-in Shower, cutting waste pipe
Hi,
I am working on a bathroom remodeling and want to recess my shower so that I can walk in at ground floor with no knee wall, and then the floor will slope down towards a drain. In order to do so, I will need to cut into the concrete floor, and then rebuild the shower pan below grade. What I am wondering is if I can cut the drain pipe lower to accomodate this.
Currently I have about 12" to the bottom of the waste pipe. I will need lose 1" because it is currently that high about the floor, and then I will also want to lower the pipe 2" to allow for a lower drain inside the shower stall. So I will be losing 3" of pipe height, leaving 9" from top to bottom of pipe. I am 50/50 on there being a pea trap , but assuming there is, is this okay to do? Is there any reason I would need that extra drain height?
Thanks,
Kevin
kevin327 is offline   Reply With Quote
Old 01-23-2012, 06:54 PM   #2
mike owes me $53 dollars
Tech Dawg's Avatar
Do you call it a pea trap because you pea in the shower
All jokes aside, you shouldn't have a problem if you only need to lose 1" of the pipe... At worse, you could change the P-trap out to 1 1/2" and adapt you plumbing to acommodate provided that your not reducing the flow.
Todd
www.aloneeagle.com
Tech Dawg is offline   Reply With Quote
Old 01-23-2012, 07:36 PM   #3
ha, when you got to go...
I will actually be cutting off 3" of the pipe total. The house was built in 1960, and I am not sure if there is actually a P-trap. I am just concerned about dropping the height of the pipe. I guess it is hard to say without knowing if there is a P-trap and what height the line comes back up to.
Old 01-23-2012, 08:07 PM   #4
Tech Dawg's Avatar
Sounds like you'll know for sure when ya tear that puppy up
Todd
www.aloneeagle.com
Old 01-24-2012, 04:05 AM   #5
DIY staff
Rewards Points: 7,174
Once you have the slab open --post a picture if you can---there is another thread going here about building a barrier free shower on a slab--If I find it I'll post a link.
70's Bathroom Remodel - Kitchen & Bath Remodeling - DIY Chatroom - DIY Home Improvement Forum
Old 01-24-2012, 07:05 AM   #6
Master Plumber
Javiles's Avatar
Rewards Points: 994
Sunken showers or flat walk ,in no shower pan needed, at least under our code.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 01-24-2012, 12:36 PM   #7
Thanks. I checked into that posting you sent. Good info. I am going to try to just remove some of the concrete, probably 3" depth, in order to install a presloped floor, paint on membrane, mud bed, then tile. So I am not planing on opening the entire floor up.
Old 01-24-2012, 01:59 PM   #8
DIY staff
It will be easier if you do! (remove the entire floor)
Old 01-25-2012, 10:42 AM   #9
I am just nervous removing all of it. But I was wondering if it would be more work to try to precision out a section, or just remove the whole thing and start from scratch. I could enlarge the pipe then potentionally. It is a small drain pipe right now, about 2" maybe. I am a landscape contractor, so I am familiar with concrete, but just not interior work.
VA code says 1.5" inch pipe on shower drain wcarroll Plumbing 3 08-10-2011 11:07 PM
cutting off cast shower drain 4just1don Plumbing 4 07-17-2011 04:50 PM
Bernoulli's Principle, increase 3/4" pipe to 1-1/4" or 1-1/2" copper ChrisDIY Plumbing 14 09-18-2010 09:49 PM
Is yellow polyethelene or polyphenol gas pipe now the preferred gas conduit? MarkSilber Plumbing 1 09-18-2010 12:10 PM
2nd floor walk in shower drain leak. h2430djm Plumbing 1 02-19-2010 07:32 PM
