W-d 40 - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-17-2011, 06:02 PM   #1
Rewards Points: 18
W-d 40
Hi,
Please someone help me with this. I have used wd-40 before
but not for water joints. I am trying to remove my hotwater
valve below the kitchen sink. First there was the mineral
deposit from probably very slight drips because i never felt any
water there, anyways I brushed that away and now it's clear enough
where all I can see is the teflon tape used to help secure the joint.
I cannot get it loose, I'm afraid of course to break it but was
wondering if I could spray with the wd-40. My concern is it getting
into the pipe itself. If it did, is it dangerous, plus I would be spraying just
a tiny amt I just need a little leverage to loosen the thing.
Sorry for the long winded post but half the time I have no idea
what I should be asking thanks for your help.
Rita2 is offline   Reply With Quote
Old 01-17-2011, 06:18 PM   #2
Could you post a pic of what it is you're trying to loosen?
VIPlumber is offline   Reply With Quote
Old 01-17-2011, 06:24 PM   #3
Rewards Points: 1,088
Originally Posted by Rita2 View Post
Hi,
I don't see how this could be "dangerous," but make sure the valve is shut off before you attempt this. I would recommend getting a bigger wrench for leverage.
handy man88 is offline   Reply With Quote
Old 01-17-2011, 06:27 PM   #4
Rewards Points: 18
Great idea. lets see if i can post it.
Old 01-17-2011, 06:29 PM   #5
Rewards Points: 18
Picture posted. I'ts the one on the left it's been closed for a long time
but trying to add the dishwasher. The other on the right goes to the sink.
I do not have a lot of space under there to really go at it and so far it will
not budge.
Old 01-17-2011, 06:32 PM   #6
not budge.
If possible, I would recommend you unscrewing the handle and that would allow your wrench greater travel/better leverage on that pug.
Old 01-17-2011, 06:32 PM   #7
Rewards Points: 18
I've had it shut off a couple days now as I soaked the joint
with a piece of rag dipped in vinegar to help remove the stuck
on stuff so no hot water in that sink right now. Thanks for your
help.
Old 01-17-2011, 06:34 PM   #8
help.
What kind of wrench are you using?
Old 01-17-2011, 06:47 PM   #9
Rewards Points: 18
I'm about to post a pic of the 2 tools I've
tried so far. I think one is a wrench.
Old 01-17-2011, 06:50 PM   #10
You'll probably need a two crescent wrenches or a small crescent wrench and channel lock pliers.
Old 01-17-2011, 06:52 PM   #11
Rewards Points: 18
Here they are. I am very fearful of having it break
on me, that's probably the biggest thing.
Old 01-17-2011, 06:55 PM   #12
Rewards Points: 18
Very difficult to use the red one because of the lack of
room and yes I tried with the valve open so little more
room with fear of hot water
omg one little thing kicking my btt.
Old 01-17-2011, 07:02 PM   #13
Rewards Points: 18
Got it didn't have to use the wd-40.
Thanks for all the suggestions was just
afraid to apply the pressure I guess. Used
another tool and now it's like, what was that
all about lol.
Thanks all.
Tags
w-d 40
