Volume Of Water In Pool - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-26-2012, 10:14 AM   #1
Arrow
Volume of water in pool
Recently i moved into a house with a pool. The size of the pool is;
30ft long x 20 feet wide. the deepest part is 6ft and the shallow part is 3ft. Can someone please help me on how to calculate the volume of water.
florida56 is offline   Reply With Quote
Old 01-26-2012, 10:23 AM   #2
Rewards Points: 256
30x20x6=3600 cubic ft
30x20x3=1800 cubic ft
If your pool is half shallow end and half deep end your volume would be 2700 ft^3.
michaelcherr is offline   Reply With Quote
The Following User Says Thank You to michaelcherr For This Useful Post:
florida56 (01-26-2012)
Old 01-26-2012, 10:25 AM   #3
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 692
I think to be more exact, we'd need to know how much of the pool is deep, how much is shallow, and if the shallow end slopes to the deep end, how long is that slope?
To add to the above post, 2700 cubic feet is about 20,200 gallons.
hyunelan2 is offline   Reply With Quote
Old 01-26-2012, 10:33 AM   #4
Thanks for your help. What i really wanted to know is how to do the math.
Old 01-26-2012, 10:41 AM   #5
hyunelan2's Avatar
Rewards Points: 692
Oh. Well, like michaelcherr pointed out, you just calculate the volume (LxWxH). If you have only 2 squared off areas (no slope), then you would do like he did in his calculations.
If there is a slope between the two areas, you'll need to calculate it out in a couple of parts (The 3' area, the 6' area, and the area above the slope) then add these areas together.
Any of these will show a result in cubic feet. 1 cubic foot is equal to about 7.48 gallons of water. So, you then multiply your total cubic feet by 7.48 to get the number of gallons. If you want to be very exact, 1 cuft = 7.48051948 gallons (Google).
Old 01-26-2012, 10:50 AM   #6
hyunelan2's Avatar
Rewards Points: 692
I'll go one step further, here is a diagram.
Assuming the 3' deep and 6' parts are both 10' wide, and the sloped part is also 10' wide, here is what you have.
Calculate up the square foot areas of each of these sections:
6x10 = 60
10x3 = 30
10x3 = 30
10*3/2 = 15 (triangle = base x height / 2)
Add them together: 60+30+30+15 = 135 square feet.
Multiply 135 x 20 (the width of the pool) = 2700 cubic feet - the same as if there was no sloped area in this case (since the deep and shallow parts are equally sized).
2700 cubic feet x 7.48 gallons per foot = 20,196 gallons.
The Following 2 Users Say Thank You to hyunelan2 For This Useful Post:
burnt03 (01-26-2012), florida56 (01-26-2012)
Spa attached to the pool suddenly lost water rmk9785e Plumbing 8 06-29-2011 10:45 PM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 11:32 AM
Very Low Hot Water Pressure. PAS1970 General DIY Discussions 2 02-25-2009 03:01 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-06-2008 11:31 PM
