Old 09-12-2009, 09:52 AM   #1
Vitreous china toilet tank repair
I purchased a house with a newer Eljer toilet manufactured in 2005 that appears fine. However is has a crack in the back of the tank that runs about 5" down from the top and seeps water. I cannot seem to locate just the tank locally and trying to repair it seems interesting.
Can vitreous china be repaired?? My thought is to drain tank,dry, sand and clean area then use fiberglass material and resin on the inside. Will fiberglass stick to china???
As usual any thoughts, ideas, suggestions, advice and wisecracks greatly appreciated.
Jim
jjrbus is offline   Reply With Quote
Old 09-12-2009, 12:13 PM   #2
I think it will work on the rough inside surface. Either fiberglass & resin patching or epoxy.
(Not on the glazed outside surface)
Old 09-13-2009, 10:51 AM   #3
Since the crack is all the way through the tank, you may find that it can extend further in the future or totally let go. Not something I would like to find when I got home from work.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 09-20-2009, 10:41 PM   #4
Thanks for the responses. I suspect you are right on the crack letting go someday. I had a large amount of resin and cloth laying around so i redid an area about 5 times the size of the crack! If I had not had the material handy, I would not have attempted the repair, less headache to just replace it..
Anyway it seems to be a sucess the material bonded well to the inside of the tank and the leak stopped. So time will tell?
Right after repairing the tank the wife said the toilet would not flush. The hole on the flapper holding the chain broke. What do people do that do not know how to fix anything?
Jim
More On This Topic
Hi this is Jon on behalf of Expert Village in this video clip I will be showing you how to remove the problem components. First I need to remove my lock nut located on the bottom of the tank. This is where our water supply came into our tank that would... Read More »
If your flapper needs to be replaced, it’s probably the simplest thing you can do. All you’re going to do is flush the toilet, let it run out- turn off the supply line first. Once you’ve drained the tank, you’re going to simply... Read More »
Hi this is Jon on behalf of Expert Village in this video clip I will be talking about identified the problem component. Now initially our diagnose was where this little flapper closes was not forming a tight enough seal that is letting the water slip... Read More »
Now, to check to see if this toilet has a leak in it, what you can do is you can take, and put a little bit of food coloring into the tank. If there is a leak in this toilet, the water food coloring will go through the tank, and end up in the bowl. So... Read More »
Hi! My name is Cathi Pare with the City of Santa Barbara Water Resource Department speaking to you today for expertvillage.com. We are continuing on our little quest of how to fix the leaks in your toilet. Early, earlier conversation we talked about the... Read More »
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Setting a Toilet tank against a tiled wall jibanez Plumbing 3 01-17-2009 08:54 AM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
toilet tank burst BillD Plumbing 4 06-30-2008 12:49 AM
Tilted Toilet Tank NotSoHandyman Plumbing 1 12-04-2007 09:23 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
