-   -   Vitreous china toilet tank repair (http://www.diychatroom.com/f7/vitreous-china-toilet-tank-repair-52846/)
jjrbus 09-12-2009 08:52 AM
I purchased a house with a newer Eljer toilet manufactured in 2005 that appears fine. However is has a crack in the back of the tank that runs about 5" down from the top and seeps water. I cannot seem to locate just the tank locally and trying to repair it seems interesting.
Can vitreous china be repaired?? My thought is to drain tank,dry, sand and clean area then use fiberglass material and resin on the inside. Will fiberglass stick to china???
As usual any thoughts, ideas, suggestions, advice and wisecracks greatly appreciated.
Jim
AllanJ 09-12-2009 11:13 AM
I think it will work on the rough inside surface. Either fiberglass & resin patching or epoxy.
(Not on the glazed outside surface)
majakdragon 09-13-2009 09:51 AM
Since the crack is all the way through the tank, you may find that it can extend further in the future or totally let go. Not something I would like to find when I got home from work.
jjrbus 09-20-2009 09:41 PM
Thanks for the responses. I suspect you are right on the crack letting go someday. I had a large amount of resin and cloth laying around so i redid an area about 5 times the size of the crack! If I had not had the material handy, I would not have attempted the repair, less headache to just replace it..
Anyway it seems to be a sucess the material bonded well to the inside of the tank and the leak stopped. So time will tell?
Right after repairing the tank the wife said the toilet would not flush. The hole on the flapper holding the chain broke. What do people do that do not know how to fix anything?
Jim
pushpa 04-17-2011 04:23 PM
Jim
Hello Jim: What has time told? We have the same problem with our Eljer tank and are thinking to repair the crack using 3M marine adhesive sealant fast cure 5200. Any thoughts or comments? By the way, what did you use the cloth for? And what kind of cloth was it? Hope you or another mamber can help.
Pushpa
jjrbus 04-17-2011 05:02 PM
Been so long I forgot about it! I checked and everything looks good. What kind of cloth? Its a fiberglass cloth like you would use for auto or boat repair and resin.
JIm 0311
pushpa 04-17-2011 10:41 PM
Thanks. I'm encouraged. Please tell me what specific products I need to purchase with step by step instructions on how to repair this crack. I have never used resin or the auto/ boat repair cloth. I'm a complete novice, you might say, but willing to learn.
Pushpa
plumber666 04-18-2011 07:54 AM
In my experience, a cracked tank should be replaced. When it eventually breaks, you'll have BIG problems. Look around for a compatable tank if you can't find an Elger.
jjrbus 04-18-2011 08:29 AM
I used the fiberglass because that is what I had on hand. If I had 3M 5200 I would have used that. A fiberglass repair kit is about $15, plus the mess of doing the job. Money might be better spent on new toilet?
I have only used fiberglass a couple of times over the years. I would Google "Utube fiberglass repairs" and you will get to see many different people using fiberglass or head off to the library for a book. Much more informative than anything I could type.
I did the repair from inside the tank. Emptied the tank, let it dry, sanded the area by hand about 3 inch either side of the crack with 150 grit sand paper. Then cleaned with alcohol. I cut the cloth about 5 inch wide and about 2 inch longer than crack.
Mixed resin and hardener soaked cloth applied over crack and removed air bubbles. Let dry. Mixed more resin and hardener and brushed over repair area.
JIm 0311
jjrbus 04-18-2011 08:39 AM
I missed 666 reply, if I could have found a matching tank. I would not have tried to repair this one. You can buy tanks separate and they may not be expensive. Try a Google search on tanks.
JIm 0311
del schisler 04-18-2011 08:55 AM
Pushpa
Make sure you use eye protection. When using resin and hardner in it get in the eye you will go blind. Nothing you can do so use caution !!! Nothing to mixing the resin and harder use equal parts and mix real good. use the cloth for boat repair and auto repain. You can get small amount in a auto supply store. most likey get a repair kit also all that you need for the tank repair
AllanJ 04-18-2011 09:34 AM
If you use the cloth as opposed to just a bead of epoxy then the chance of the tank's splitting open further is greatly reduced.
jjrbus 04-18-2011 09:42 AM
The resin came in a big can, the hardener in a small tube. So equal parts does not seem right?
JIm 0311
Homerepairguy 04-18-2011 01:39 PM
Pushpa
Pushpa,
Realize that if the tank lets go when you're not at home or even worse, on a week long vacation, then your home will be flooded. The valve in the tank depends on water to lift a float to shut the valve off. No water = no shut off.
If you are determined to try to patch the repair, you can use silicone sealant and fiberglass cloth. Silicone will stick to the china much better than fiberglass resin. It remains flexible and will not become brittle like fiberglass resin. It's used to hold aquariums together. --- Dry the tank, sand down to the china, spread the silicone on the china around the crack, stick the fiberglass cloth over the crack, apply more silicone over the fiberglass cloth. Let it dry for at least 24 hours. --- Then hope it never lets go and floods your home.
A new toilet seems like cheap insurance to me, to prevent the huge losses that a flood can cause.
HRG
pushpa 04-20-2011 10:25 AM
Thanks. I have tried very hard to find a tank compatible with my natural colored Eljer 1605 toilet but have not succeeded. Is it really true that no compatible tank exists?
Pushpa
