Vibrating Pipe After Replacing Washer In Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-19-2012, 02:28 PM   #1
Vibrating Pipe after replacing washer in faucet
My hot water faucet was causing a drip so I replaced the flat faucet washer in it and the dripping stopped but sometimes when I turn on my hot water faucet the pipe starts to vibrate loudly causing the floors to shake. The cold faucet is fine and all the other faucets in the house are fine except this one that I replaced. This never happened before and I've bought some copper U hooks and nail down the hot water pipe but it still happens. Nothing has changed since the washer but I'm trying to figure out what exactly is going on? Is something too tight, too loose? Any ideas? Thanks!
mikegoa is offline   Reply With Quote
Old 09-19-2012, 08:05 PM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Try a differant washer,could be creating a restiction inside faucet somehow.
Normally this happens when you have a valve that shuts off too fast making pipes rattle.
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 09-19-2012, 08:22 PM   #3
Rewards Points: 582
sounds like a loose washer..take it back apart tighten screw or replace it with a coated bibb screw make sure its tight to the washer....
The Following User Says Thank You to ben's plumbing For This Useful Post:
plummen (09-19-2012)
2" pipe on above sink in wall rusted out in a spot bryanp22 Plumbing 9 02-23-2012 08:29 PM
Replacing 2 handle faucet with single handle faucet vcheez Plumbing 6 10-19-2011 10:26 AM
How to clean a PVC waste pipe from rubber washer remains? sukhenkoi Kitchen & Bath Remodeling 3 03-04-2011 10:10 PM
Hot water faucet pipe thumps then flow slows down. DIY-Indy Plumbing 9 07-15-2009 11:09 PM
washer drain pipe paydelady Plumbing 3 11-13-2007 12:27 AM
