Vessel Sink HELP - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-22-2009, 09:19 PM   #1
vessel sink HELP
Installed a vessel sink and granite counter top. The total distance from from the top where the drain goes to the bottom of granite counter is 2 7/8 inches. I have purchased 2 drains and they are short. Been to plumbing supply stores and they say they don't make threaded extensions. I need help. I need an either an extension that I am able to thread and tighten or a drain that is at least 3" so I can tighten so the sink will not leak. Any help is appreciated.
Jim
surfernj is offline   Reply With Quote
Old 02-23-2009, 09:16 PM   #2
maybe this will help
They do make a few drain styles that should work seeing that this type of sink is popular. the drain may have a push down pop up style and they also have a style that you lift up and push down. these tend to have a longer thread pattern. check online stores and other outlets other than your supply house. you may have to spend a lot on this but it may help. try this link check the specs tab. good luck
http://www.homedepot.com/webapp/wcs/...3+90401+500492
plumbbum0203 is offline   Reply With Quote
Cast iron self-rimming kitchen sink & granite tile ILjXYZ Kitchen & Bath Remodeling 1 01-03-2009 06:53 PM
Vessel sink fits loose on counter top jam12 Plumbing 3 11-20-2008 06:02 PM
Vessel sink doesn't drain completely Lin Plumbing 3 04-25-2008 12:35 AM
Vessel Sink height and faucet height KCourtland Plumbing 1 09-30-2007 08:39 PM
installing vessel sink drain?! (HELP!) tara Plumbing 2 11-10-2006 01:17 AM
