-   -   vessel sink HELP (http://www.diychatroom.com/f7/vessel-sink-help-38963/)
surfernj 02-22-2009 09:19 PM
vessel sink HELP
Installed a vessel sink and granite counter top. The total distance from from the top where the drain goes to the bottom of granite counter is 2 7/8 inches. I have purchased 2 drains and they are short. Been to plumbing supply stores and they say they don't make threaded extensions. I need help. I need an either an extension that I am able to thread and tighten or a drain that is at least 3" so I can tighten so the sink will not leak. Any help is appreciated.
Jim
plumbbum0203 02-23-2009 09:16 PM
maybe this will help
They do make a few drain styles that should work seeing that this type of sink is popular. the drain may have a push down pop up style and they also have a style that you lift up and push down. these tend to have a longer thread pattern. check online stores and other outlets other than your supply house. you may have to spend a lot on this but it may help. try this link check the specs tab. good luck
:eek:
http://www.homedepot.com/webapp/wcs/...3+90401+500492
