Very unusual problem with my boiler
Hi people,
I have a Worcester Bosch 24 CDi boiler. I have had this since 2004. It has been working brilliantly since then.
However, in the last few days we haven't been getting any hot water. In fact the only time we get hot water is when we switch on the heater button on the boiler (you know with the thermostat). Other then that, no hot water. Even with the heater switch on, sometimes hot water comes and sometimes hot water doesn't. We don't what's going on. Also we don't get any water coming through our toilet either. Both of these happened at the same time.
Anyone knows what's going on?
The middle red light on the boiler (which has the tap sign on it) doesn't come on either.
If it helps, this happened at a time when our main water pipe was leaking and was in the process of being repaired and the workers did switch the main water pipe off several times whilst our boiler was on and heating was on.
