Very Strange PEX Plumbing, Is It A Good Idea To Replace It? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-04-2011, 07:29 AM   #1
Very strange PEX plumbing, is it a good idea to replace it?
After removing the tub in a bathroom renovation, I saw the plubming shown in the attached images.
The tube going under the tub will definitely be replaced. But what about the two tubes going up with all those elbows in them? Do they restrict the flow? (Note that these tubes go directly to and from the water heater on the other side of the wall, which means that all the hot water in the house goes through them.) And is there a better way to make a PEX tube to go out of a wall and turn 90 degrees than two elbows?
Very strange PEX plumbing, is it a good idea to replace it?-dscf0922.jpg   Very strange PEX plumbing, is it a good idea to replace it?-dscf0924.jpg   Very strange PEX plumbing, is it a good idea to replace it?-dscf0925.jpg
mtk369 is offline   Reply With Quote
Old 09-04-2011, 09:12 AM   #2
Plumb or Die!
That grey pipe is polybutylene, and was outlawed years ago. Yeah, there's better ways to run all those water lines, but the first step is to remove ALL of the PB.
plumber666 is offline   Reply With Quote
Old 09-04-2011, 01:30 PM   #3
Civil Engineer
Rewards Points: 4,778
And the white pipe is probably not PEX either, perhaps it says on the pipe itself. The elbows definitely create pressure loss, but maybe not a big problem, if your pressure at the source is adequate. The polybutylene piping is likely a bigger issue than the elbows.
Old 09-04-2011, 02:04 PM   #4
i would remove that mess if that is called plumbing and do it right. total cob job. somebody did not know what they were doing.
good luck !
handyman8494 is offline   Reply With Quote
Old 09-04-2011, 04:05 PM   #5
All of the tubing is PEX, it says right on it. It's a mixture of various brands of PEX tubing, though, not just one.
And I once did another project that involved revoving some of the gray tubing, and it is actually white. The dark color was from mineral buildup on the inner surface of the tubing.
Old 09-05-2011, 09:56 AM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 1,824
Slightly off topic.....what is with the peg board on the wall? Ventilation into the insulation?
Seeing your pics makes me glad I have copper.
Old 09-05-2011, 06:55 PM   #7
I would start over...
1910NE is offline   Reply With Quote
Flatscreen over the fireplace? Is this really a good idea? kashimama Home Theater 43 11-19-2011 11:01 PM
Laminate & hardwood in the same room, good or bad idea?? phatjoe Flooring 10 05-14-2011 09:57 PM
Strange Plumbing Problem elementz Plumbing 17 02-17-2010 10:48 PM
SLATWALL storage solution for Garage, Good Idea?... KUIPORNG General DIY Discussions 9 01-29-2008 09:15 PM
re-using redwood fencing - a good idea? gulleyj Building & Construction 1 08-08-2007 09:40 PM
