Old 01-17-2009, 12:14 PM   #1
Default Very noisy radiator in bedroom...Need help and sleep.
The radiator in my bedroom has a very noisy habit. When it heats up it begins to make a terrible racket. I can only describe the sound as this, imagine a tiny gremlin trapped inside my radiator throwing a golf ball against the metal sides as hard as he can.
It always seems to happen at night and early in the morning, stealing my precious sleep. Is this normal? None of the other radiators in my house make this sound. None of the other radiators get as hot as the bedroom one either. It is hot in the morning even with the knob turned all the way off. WHat can I do. Attached are pictures of my radiator in the bedroom.
Levib2004 is offline   Reply With Quote
Old 01-17-2009, 03:29 PM   #2
biggles's Avatar
that silver vent should hissssssssss when the heat is up,the gremlin could be water trying to leak back to that shut off on the other side as the stream comes up.if you have a liquid level you need to tip the radiator towards the shut off put a piece of wood on top of the radiator then the level on that to get an idea if it is tipped that way.shim it up on the vent end feet 1/4...1/2 to move the bubble in the level...as steam cools it turns to hot water.either it goes out the vent as steam or back to the boiler.if that is an outside wall,and gets ice cold in the night with the winter.a sheet of foil backed styrafoam (1/4" at HD)sheet will keep the cold off the radiator and reflect the heat into the room.check all the radiators around the whole place for the tilting back to that shut off.if you have radiators over heating a couple of half/full CW turns will send the steam to the next radiator.....that silver vent should be hand tight and when removed(no heat running) rattle when you shake it.
More On This Topic
On behalf of expertvillage.com, my name is Dean Forrest with Sedona Coffee Roasters. I am here to tell you about roasting coffee. Okay a few minutes have gone by now and our second crack is starting. This crack is not a steam issue any longer. What... Read More »
Hi, my name is Tommy and we are speaking with, on behalf of Expert Village today. We're going to talk a little bit about radiators. There's different styles of radiators, any of the water cooled motors have to have a radiator on them. This is one of the... Read More »
A space heater can save money on gas and electric bills because it heats only a small area and efficiently converts almost all of its energy into heat. However, heaters can pose a serious danger from fire and toxic air pollution. Reduce these risks by... Read More »
Hi! I’m Louis Ortiz on behalf of Expert Village and I’m back to show you the chicken strips which we’ve breaded. So I’ve got a countertop fryer here that works really well, I got it set to 375 degrees and as you can see my ready... Read More »
Hello, I'm Mark Blocker with Expert Village. In this segment were going to cover the heating and cooling system. In many of today?s new automobiles they have an air bypass valve installed on the cooling system. As I described before there is a thermostat... Read More »
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
