Very Low Pressure On Bathtub Faucet/ Showerhead - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-08-2009, 07:27 PM   #1
Very low pressure on bathtub faucet/ showerhead
Please help. The bathroom was remodeled but never used. Now that finaly we want to use it when I open the bathtub faucet the water pressureis very low. Not even enough water to make the showerhead work! If I open the sink faucet and leave it on while I have the bathtub faucet running then the water pressure increases and I can actually make the showerhead work just by pulling the little lever. I have checked for devris in the showerhead and bathtub faucet, but it does not seem to make a difference.
I like trying to fix things by myself, but I have not had any luck with this. Any suggestions anyone?
Thank you.
Isabel
Mermarisa is offline   Reply With Quote
Old 10-09-2009, 09:53 AM   #2
Make sure you don't have a shutoff valve partly closed someplace also remove the shower head and see if you get pressure to it while it is off. Maybe the shower valve has integral stops.
plumber Jim is offline   Reply With Quote
Old 10-09-2009, 11:36 AM   #3
Low water pressure in bathtub faucet/shower
Thank you so much for your advice I'll try that.
Mermarisa
Old 10-09-2009, 12:52 PM   #4
Thank you.
Isabel
So when you open the sink valve and the bathtub valve....the water increases? Do you have a boiler with a multi speed circulating pump? It doesn't make sense opening up a sink valve to increase flow through the tub.
How is the bath tub plumbed? is it attached to the sink plumbing?
is the plumbing new as well? it could just be air in the lines...does it still do it? is the water sputtering out, like there is air in the line?
Viper16 is offline   Reply With Quote
Old 10-09-2009, 02:23 PM   #5
I do not know much about the water heater except I foud out yesterday that it does not work and it needs to be replaced. Do you think that has something to do with it? About the plumbing I do not know much either just that it was replaced when I bought the place. (lAbout 6 months ago) The guy who installed it just told me that the plumbing was installed just like the original plumbing. The only difference is that he used copper pipes instead of the galvanized pipes and according to him it was working properly when he installed it. This placed had been vacant since it was fixed.
Thank you for your help!
Old 10-09-2009, 03:25 PM   #6
I could see that if the hot water heater was clogged...and you had the hot water valve or mixing valve all the way on, and there was no pressure, then something is wrong with the heater.
Unsure how the counter sink has any affect.
Old 10-10-2009, 01:45 PM   #7
Problem Solved!! Thank you so much
Thank you all for all your help. Problem solved!!
Plumber Jim you were right!! The water heater valve was partially closed. The water pressure is back to normal. Now, I just have to replace the water heater.
Old 10-10-2009, 11:47 PM   #8
Glad to hear it! good luck on your heater.
Low water flow bathtub faucet osirus065 Plumbing 3 09-07-2009 11:51 AM
Leaky Delta bathtub faucet DOW Plumbing 4 01-04-2009 08:33 AM
No hot water pressure at kitchen faucet tracker883 Plumbing 2 12-30-2008 05:10 AM
Bath Faucet pressure weak blackbart1721 Plumbing 1 12-29-2008 07:13 PM
Low hot water pressure on kitchen faucet Ultrarunner2017 Plumbing 7 12-19-2008 09:49 AM
