Very Little Water Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-10-2011, 02:08 PM   #1
I have a Culligan Mark 89 that is over 20 years old. I've had ALOT of trouble with water pressure for the past 4 years. When you first turn on water anywhere in the house it has great pressure, but within a few seconds it goes to nothing. You cannot have water running in two places at the same time. I recently changed the regen on the softener to every night and cleaned out the salt tank, but this hasn't helped. Any ideas?
ciel19 is offline   Reply With Quote
Old 06-10-2011, 03:18 PM   #2
Rewards Points: 27
Post
Poor water pressure
At first blush, this sounds like a bad water softener - the unit may be clogged from the age of the system. If possible, by pass the softener temporarily and see what happens. Some softeners are equipped with a bypass valve. If the softener has an inlet strainer, check it and clean as needed.
Also check your incoming water pressure especially if you are on well water. Make sure the main inlet water valve is all the way open. If it has a strainer, check that as well. You should also exercise this valve periodically (open and close it). Sometimes they become clogged or trap something (like sand).
OldSingy is offline   Reply With Quote
Old 06-12-2011, 09:37 PM   #3
Bypassed system and pressure was great. Now what?
Old 06-13-2011, 12:19 AM   #4
Rewards Points: 27
Post
Poor WQater Pressure
It sounds like you need a new water softener. It is possible to flush and replace the zeolite bed in the softener, but given the age of the unit according to your earlier information, it wouldn't be worth it.
Poor Hot Water Pressure After HW Heater Flush linuxrunner Plumbing 4 04-07-2011 08:24 PM
hot water pressure much lower than cold water pressure lockingpin Plumbing 5 12-26-2009 05:23 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 02:02 PM
Low water pressure upstairs but gauge reads 100psi? rivers72 Plumbing 7 11-15-2008 08:55 PM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 12:19 PM
