Old 02-04-2009, 03:00 PM   #1
transmitterrecieverpntgun
Very important water heater question about pressure valve!?!
Does this have a pressure valve and is it installed properly???? It seams that the water goes in through the top comes out the side....
Very important water heater question about pressure valve!?!-p1300124.jpg   Very important water heater question about pressure valve!?!-p1300127.jpg   Very important water heater question about pressure valve!?!-p1300129.jpg   Very important water heater question about pressure valve!?!-p1300126.jpg
utilitylocator is offline   Reply With Quote
Old 02-04-2009, 03:07 PM   #2
The pressure valve was on the side, it is seen in the second picture. Is it a new tank? if so i would think it was misintalled, mind you most tanks come with them already installed... if it is an older tank it is probably a faulty valve which you would need to replace. You can buy one for about 10-15 bucks.
scotty123 is offline   Reply With Quote
Old 02-04-2009, 03:18 PM   #3
Moderator
Termite's Avatar
There is absolutely nothing to indicate that the valve is vaulty or improperly installed. There are/were many configurations of water heaters and a number of locations for T&P's.
The T&P valve is mounted on the side in the 2nd picture. Nothing wrong except that it should have a pipe that drains it down close to the floor. That way nobody gets burned by steam/hot water coming out of it if there's a problem.
Old 02-04-2009, 03:22 PM   #4
Thanks for the informtion!!
Old 02-04-2009, 03:22 PM   #5
Thanks!!
Old 02-04-2009, 04:27 PM   #6
If water is coming out of it... wouldnt it be faulty or improperly installed? Not trying to be rude, but maybe you know something i dont.
Old 02-04-2009, 04:41 PM   #7
Xtreme DIY'r
The water coming out thru the side is the "normal" hot water output for this tank (flex pipe). The T&P valve is also on the side - no pipe - it should have one going near to the floor as stated
Old 02-04-2009, 05:21 PM   #8
Moderator
Termite's Avatar
I interpreted the original post to mean the inlet and discharge locations, not that the T&P itself is leaking. When T&P's leak the easiest thing to do is spend a few bucks and replace them.
Old 02-05-2009, 02:21 PM   #9
ahh i see, i thought the pressure relief valve was leaking.
Old 02-05-2009, 06:18 PM   #10
The flex pipe on the side is the water (cold) intake. The cpvc pipe coming out the top is the water (hot) out. The top is marked hot by the manufacturer and the release valve is in the hole marked for it as well. It does seem to me that the hot should have the flex line though?!?!
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 02:02 PM
Multiple hot water heater issues a-6intruder Plumbing 8 01-16-2009 06:58 PM
Insane water pressure in shower!!! Sarah24 Plumbing 5 12-09-2008 06:27 AM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-07-2008 12:31 AM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 01:43 PM
