Vertical Pipe Support - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-14-2012, 01:56 PM   #1
Vertical pipe support
Hello all. I installed some half inch copper piping for a stove pot filler. There is one run that is almost 5 feet vertical being supported by clamps on the pipes that branch off of it at each end. Is it necessary to also clamp the center? I'm just wondering if that is too much weight for the elbow joints to support. Thanks
Kuma71 is offline   Reply With Quote
Old 06-14-2012, 04:50 PM   #2
DIY staff
Rewards Points: 7,174
5 feet between clamps is fine--in case I misunderstood your description--add a photo if you can.
Are the eared flanges for the faucet well secured? (If that is the typical restaurant style faucet)
Leaking drain pipe under kitchen sink dethun Plumbing 22 03-13-2016 05:53 AM
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
replacing cast iron pipe davemarz Plumbing 1 05-20-2011 09:16 PM
Max horizontal load on vertical basement support beam supa Building & Construction 8 02-27-2011 01:51 PM
Alterative ways to support main beam frizbplaya Building & Construction 8 01-28-2011 11:10 PM
