Vertical Float Switch For A Flotec Sump Pump - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-23-2009, 07:00 PM   #1
Kimp
Vertical float switch for a flotec sump pump
I am currently on my third(3rd) new switch in the past three years! It is very frustrating having to change these switches all of the time. I have a backup sump pump, but I just want the primary one to work. I have been in my home over 15 years--is it time for new pump, and which one should I buy? I don't want any more problems with switches..
Kimp is offline   Reply With Quote
Old 02-23-2009, 08:53 PM   #2
time to replace pump
You should just replace the pump with a new one. A great brand to buy would be a Zoeller mighty mate they are a cast iron body heavy duty pump.
they are easy to install and reliable. You can check your local plumbing supply house. these generally are not found at big box stores. The float is on the side and wont hang up like a tethered float. they also have a 1 1/2 inch discharge. I hope this info helps
plumbbum0203 is offline   Reply With Quote
Old 02-24-2009, 11:17 AM   #3
Kimp
Thanks Plumbbum! I will take your advise, and I will let you know how it works out! Kimp
Sump pump pit water level --- problem de12 Plumbing 52 01-14-2016 08:46 AM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 07:09 PM
Sump Pump Design handy man88 Plumbing 2 10-04-2008 10:48 PM
Foundation drain and sump pump slatergrl Plumbing 3 02-10-2008 10:36 AM
sump pump continuing running deck hand Plumbing 2 01-16-2008 05:35 PM
