Vertical Drop - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-17-2012, 11:20 PM   #1
Vertical Drop
Background Information
- New Build (2011)
- Ottawa/ON - Canada
Hi,
I'm trying to figure out whether or not there is a code regarding noise or maximum vertical drop of water drain. I noticed a loud noise coming from the water drain pipes in the basement when the water is being used elsewhere in the house. Almost sounds like the water is coming down in a free fall until it impacts the horizontal section of the pipe and makes a splashing noise.
Anyone experience this ? Is this to code?
GeorgesAA is offline   Reply With Quote
Old 04-17-2012, 11:52 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 348
Not really any code restrictions on height for a typical house. Plastic can be load though
Old 04-17-2012, 11:55 PM   #3
Hi George,
There are no Cdn plumbing code regulations regarding the level of noise a water line or drain line makes. You can hear water draining through the pipe if it's marked SCH 40 (most common wall thickness of ABS used in drainage lines that I'm familiar with). You could try to upgrade to SCH 80 if the noise is too aggravating, but my drains are SCH 40 and in the crawl space, and unless I'm working nearby, I don't hear them.
VIPlumber is offline   Reply With Quote
Basement - drop ceiling jgrohol Building & Construction 11 04-01-2011 01:39 PM
Max horizontal load on vertical basement support beam supa Building & Construction 8 02-27-2011 02:51 PM
Could I move my Meter & Power Drop to the Side of my house? jamiedolan Electrical 9 07-28-2010 06:16 PM
Drop Ceiling Prices? bengbrewer Remodeling 8 03-18-2009 03:00 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
