Venting Of Two Bathroom Sinks - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-04-2011, 01:45 PM   #1
venting of two bathroom sinks
I have a 4 inch vent from the roof down into the attic space and I need to tie it into two separate drains for both the sinks (they are 2 inch drain pipes).
The wall is 2 x 4 inch framing. Is it ok to reduce the 4 inch attic vent to a smaller size and how should I connect it to the two sink drains?
Sandramc is offline   Reply With Quote
Old 08-04-2011, 10:50 PM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
It's kinda hard to give you an idea what to do, I don't have a diagram to go off of or anything like that.
I do know that you can't reduce the size of a vent or "choke it down".
Journeyman Plumber
Old 08-05-2011, 08:12 AM   #3
Long-Time DIYer
Mike Swearingen's Avatar
Sandra,
Without a schematic of what you're dealing with it is very difficult to advise you.
However, if these two sinks are side-by-side bathroom vanity sinks, then they should need only one shared trap and one vent after the trap.
The easiest thing to do is to install an air admittance valve under the sink base after the trap, IF allowed by your local building code.
Check out www.studor.net about AAVs. Studor is a well-known worldwide brand name,
Then call your local building inspection department to see if AAVs are allowed in your jurisdiction. They are easy to install right after the trap under the sink with basic plumbing skills.
The alternative, if AAVs are NOT allowed, is to run a 2" pipe from a T in the wall behind the sink base with the trap draining into the T (and a 2" vent going up to a 2" connection to a 4" fitting installed in the vent pipe going up through the roof). The T will allow the water to drain in and downward and the air to come in from the top to vent it.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Bathroom fan venting??? titan7 HVAC 1 03-01-2011 04:10 PM
Bathroom Exhaust Fan Venting into Attic koz123 HVAC 10 01-21-2011 09:05 PM
basement bathroom drain venting tbru Plumbing 2 01-17-2010 06:30 PM
Venting basement bathroom fixtures ccathy247 Plumbing 1 11-01-2008 04:44 PM
Bathroom venting g1246 Remodeling 4 04-11-2007 05:30 PM
