Venting A Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-17-2011, 01:13 PM   #1
Venting a toilet
Hello,
I'm in the process of finishing my basement, and when the house was built about 10 years ago, the basement was roughed in for a bathroom.
The question I have is I got a lot of pipes sticking up from the floor and I want to make sure that the pipes I want to use for the bathroom sink and toilet are correct and that they can be vented properly.
If you look at the pictures http://picasaweb.google.com/rfox264/...eat=directlink I have two pipes coming up through the floor, one for the toilet, and one for a shower...I believe. I would like to use the one for a toilet and cutoff the one marked for a shower. The one pipe that the toilet feeds into goes to the wall and is stubbed up about a foot. I would like to install a T and use this pipe for a sink drain, and extend it up and out for the toilet vent...if that's possible??
Any thoughts?
Thanks!
Itchbo is offline   Reply With Quote
Old 01-17-2011, 04:35 PM   #2
Rewards Points: 1,014
Yes, it looks possible to use a sanitary tee and tie a vanity into the vent for the toilet. This vent would continue up and be a wet vent for the lav and the toilet.
You are going to abandon the shower?
Anti-wingnut is offline   Reply With Quote
Old 01-17-2011, 05:27 PM   #3
Thanks Anti-wingnut!
No, I'm not going to put the shower in because its stubbed up where I'm going to put the bedroom. I'll just cut it off flush to the floor and plug it.
Thanks!
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Toilet venting Master Brian Plumbing 5 08-24-2010 12:05 PM
Moving toilet need venting advice jadrma Plumbing 6 03-14-2010 07:25 AM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Help: Toilet venting and critical distance Nwl_one Plumbing 4 07-17-2009 01:27 PM
