Venting Tankless Water Heater Vertically - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-24-2010, 08:25 PM   #1
venting tankless water heater vertically
I have a one level house on a concrete slab, no basement. I got a tankless water heater, and because of limitations on placement I have to vent it vertically through the attic and roof. The vent that I have is 3" single wall. I'm going to blow insulation in the attic eventually, and was wondering if there would be a clearance issue. Is the insulation going to catch on fire? What can i do to keep the insulation off the vent? They make an adapter for the 3"/5" concentric pipe which I think would do the trick with the 1" of air space around the 3" pipe, but the adapter has openings in it. Cold air from the outside would rush right down between the walls right into my house in the winter. My water heater isn't set up for the concentric pipe, it takes in combustion air from the room. Any suggestions?
tycobb is offline   Reply With Quote
Old 07-25-2010, 10:32 AM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
I'm pretty sure you can't put that thing somewhere where it uses the room air for combustion. It'll kill someone.
Journeyman Plumber
Old 07-25-2010, 06:08 PM   #3
What do you mean by that? How is drawing combustion air from a room going to kill someone? The instructions just say not to put it somewhere where you store combustable materials like solvents and paints and stuff, so it doesn't take in cumbustable vapors.
Old 07-25-2010, 11:56 PM   #4
Doing it myself
Alan's Avatar
I'm going to go out on a limb and say since you're asking that question, you probably should just hire a pro. . .
Journeyman Plumber
Tankless water heater to pre-heat incoming water matthet Plumbing 35 01-06-2017 01:39 AM
Tankless Water Heater welshie Plumbing 12 03-03-2010 01:46 PM
Tankless Water Heater Problem Thalweg Plumbing 4 12-10-2009 01:18 PM
Tankless water heater vs. electrical water heater? imola ghost Electrical 19 09-08-2008 03:59 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
