Venting Soil Stack - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-04-2010, 01:20 PM   #1
venting soil stack
Hi, I am interested in putting a bathroom in my basement. I want a saniflush system, I had a plumber come out he said no problem, he was going to vent it into the sewer line. I called saniflush and they said it has to be vented to the roof. Can vent it to a 1st floor soil stake (can it share the same one). The bathroom in the basement would be about 30ft away from the bottom of the other toilet and sink where i could go up the wall and tie into the soil stack. Their would be 6 or 7 bends to get their.
Rich
I am looking for the vent part not the sweage line
rb76 is offline   Reply With Quote
Old 08-04-2010, 01:30 PM   #2
how to run the vent, can't get one to roof, can i tie into bathroom up stairs.
I am in the process of finishing my basement and decided to use a Saniflo Saniplus macerating pump unit for lifting wastewater from a sink, toilet, and shower into the existing 4 " drain line (the 4" drain exits the basement approximately 4' from the basement floor). The force main is the easy part, since the drain line runs directly above the new pump unit, but there is no convenient vent stack available to tie a vent line into. Are there venting alternatives (Saniflo says that cheater vents won't work since the unit needs two-way air flow)?
3 threads on same install merged
Moderator
Question about venting nag Plumbing 0 06-07-2010 04:20 PM
Replace outdoor cast soil stack with PVC/ABS crazychef55 Plumbing 1 01-15-2010 08:12 PM
Help with soil stack leak tmbrink Plumbing 10 03-08-2009 11:44 PM
Soil stack "cover"? DIYGmaLynn Plumbing 3 09-04-2006 01:23 AM
DWV Stack Question dcgray2 Plumbing 9 07-14-2006 01:56 PM
