Old 12-25-2010, 10:26 PM   #1
I ask the impossible!
Venting a sink pump
Okay, let me start off by explaining the situation..
The configuration of my house:
The sewer pipes connect to a city sewer system under the street, the main 4" pipe is under my driveway and connects to a 4" main stack which directly serves fixtures in a first floor bathroom and a second floor water closet directly above.
Under the dirt, a clay pipe branch rises out of the ground to connect to the kitchen sink drain, the kitchen sink being on the opposite side of the house. This branch also serves a utility sink into which the laundry drains, this piping is underground. The laundry room is on a slab, the remainder of the house is on crawlspace with dirt floor.
No venting was installed for the kitchen or utility sink, not even air admitance valve.
The clay pipe between the main stack and kitchen drain has collapsed. Not fully confirmed, but a blockage definitely exists and the problem was detected when water seeping up through the dirt was observed around the pipe coming out of the ground for the kitchen.
I am replacing it with a PVC system over the dirt. For the kitchen sink, achieving proper slope is no problem. The utility sink trap is too low and in order to tie in to the drain system near the kitchen, a sink pump is required.
Direct venting the sink pump is no problem, in fact due to windows obstructing direct venting of the kitchen, I plan to tie the kitchen vent into the utility sink vent. I'm just confused about where venting needs to tie in for the sink pump.
The pump itself provides an inlet, an outlet and a vent fitting. I bought a kit that includes a 7 gallon tank into which a sump pump goes, which is included in the kit, so the tank is vented. From the pump outlet, I'll be going up 2 feet then across to the kitchen sink.
My question is, does the outlet from the pump require to be tied to the vent where it begins going across horizontally? Or does this risk pushing water up into the vent, defeating the venting and maybe that makes it something I shouldn't do, just providing venting for the tank and where the drain ties in at the kitchen sink?
I tried reading through IPC, but honestly I can't tell if it has anything to say about this or not.. As an engineer, all I can think is that since this is a pressurized system rather than a gravity system, I can't feel certain that the rules for gravity systems with which I'm familiar necessarily apply.
I appreciate anyone taking time over Christmas to answer this, and as this all came up right before the holiday, consulting my AHJ is out until Monday, and with laundry and dishes accumulating, the wife has no interest in waiting that long.
WillK is offline   Reply With Quote
Old 12-26-2010, 12:33 AM   #2
Venting a sink pump
all the gravity drainage rules apply when using a pump (at least in my area). when connecting the vent, you can run the vent for the basin with the fixtures its serving, but I like to tie the pump in above the flood level of the fixtures as to prevent water from entering the vent pipe. run the two up side by side and connect them into one pipe to go thru the roof. hopefully this answers your question
the_man is offline   Reply With Quote
Old 12-26-2010, 02:21 PM   #3
Venting a sink pump
Thanks. Clearly the lack of sleep was affecting me, I'd been up till 2:30 AM then 3:30 AM leading up to Christmas with a 4 & 5 year old both getting up at 5:30!
I'll join the laundry vents ( vent the discharge and join that in to the basin vent) so that they enter the stack for the kitchen sink as close to the ceiling as possible.
Utility Sink Drain Pump gellswor Plumbing 3 11-07-2010 08:34 AM
disposal sink flange without the disposal? wolfv Plumbing 2 04-29-2010 07:24 AM
Shallow well pump issues, spinnb7 Landscaping & Lawn Care 1 04-13-2010 02:04 PM
Low Well Pressure, Submersible Well Pump, Help Please! tpolk Plumbing 7 11-13-2009 07:13 PM
sump pump continuing running deck hand Plumbing 2 01-16-2008 05:35 PM
