Old 11-20-2010, 08:57 AM   #1
Venting a sink drain pump question
I am installing a utility sink in the basement that requires a drain pump, I am considering a Liberty 404 or Hartell LTA-1.
I am discharging into the main waste line (3" PVC), and adding a vent at this discharge point.
Question: The Liberty 404 requires a vent. Can I tie this vent into the new vent point that I am adding where the discharge of the pump enters the waste line or do I need to add a seperate tie point into the vent for the pump? Do I need both of these vents?
[IMG]file:///C:/Users/Gary/AppData/Local/Temp/moz-screenshot.png[/IMG][IMG]file:///C:/Users/Gary/AppData/Local/Temp/moz-screenshot-1.png[/IMG][IMG]file:///C:/Users/Gary/AppData/Local/Temp/moz-screenshot-2.png[/IMG]
gellswor is offline   Reply With Quote
Condensate pump install question kboorman HVAC 6 07-06-2012 08:54 PM
Question regarding floor drain and sump pump combo vetting Plumbing 9 07-29-2010 02:10 PM
venting kitchen sink drain illinifan Plumbing 2 05-03-2009 08:26 AM
utility sink pump installation rcassidy Plumbing 1 02-17-2009 10:34 PM
Well Pump to Generator Question Sprice Electrical 1 02-11-2009 12:27 PM
