Venting Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-04-2011, 10:18 AM   #1
venting question
My first post here, so i will do my best to explain myself since i have no pictures to post. I have a bathroom that was roughed in downstairs when the house was built about 10 years ago. I am moving where they placed the tub rough-in because it wont work where it is. My drain work starts with a sink rough-in drain on one wall where it is vented with a 1 and 1/2" vent. Then then about 9 feet down the wall is where the new tub will be placed. My question is will the one vent be sufficient for the tub as well or will i need to vent the tub sepparately? It would be a huge problem to vent the tub if i did'nt have to. All of this runs to a sewage ejection pit in the basement which is then pumped out to the septic system. Thanks for any help you can give
East2West is offline   Reply With Quote
Old 01-04-2011, 11:47 AM   #2
I believe 9 feet is too far for wet venting.
bkeech is offline   Reply With Quote
Old 01-04-2011, 07:47 PM   #3
In my code book, max is 6 feet
the_man is offline   Reply With Quote
Old 01-05-2011, 08:50 AM   #4
Plumb or Die!
In my code book, wet vent length is not restricted, trap arms are. The drain pipe acting as the wet vent portion should be 2", though. The dry portion above the sink tee can be 1 1/2".
plumber666 is offline   Reply With Quote
Gas furnace venting Qs (non high eff) WallyWoggle HVAC 6 12-09-2010 06:41 PM
Question about dryer venting jimithing78 HVAC 10 08-26-2008 11:37 AM
Rheem classic 90 plus venting question jjconst07 HVAC 2 07-04-2008 05:14 PM
venting question any pros? THEBIGPUNN Roofing/Siding 3 02-06-2006 08:19 PM
