Venting Question On 2nd Floor Kitcken - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-20-2011, 10:34 AM   #1
venting question on 2nd floor kitcken
I'm building a new farm shop and am installing a kitchen area in a 2nd level space. All that will drain from here is a kitchen sink. The toilet and sink and shower will be directly below on the main floor. My question is this. Do I have to vent this upstairs and down? I will be using a Studor valve as a vent.
farmboy003 is offline   Reply With Quote
Old 06-20-2011, 11:12 AM   #2
Rewards Points: 320
If you have a studor vent for the kitchen sink, you're good.
You're just referencing the upstairs sink right, or are you saying you'll use a studor vent for the whole thing?
autx790 is offline   Reply With Quote
Old 06-20-2011, 11:18 AM   #3
The whole thing. I would prefer to not put that vent pipe through the attic and roof or outside the new building and then through the roof.
Old 06-20-2011, 11:21 AM   #4
everywhere i have worked you had to have at least one vent the full size (3") through the roof to meet code. but if there is no inspection you can do anything you want. i would run a 3 inch vent up and through the roof from the first floor plumbing.
Old 06-20-2011, 11:30 AM   #5
Rewards Points: 320
I think you need to have a vent running outdoors
http://publicecodes.citation.com/ico...017_par009.htm
Old 06-20-2011, 11:35 AM   #6
Rewards Points: 320
It doesn't have to be a single 3" vent, but there is a chart (i forget the details/units) that says you need to have an equivalent venting capacity depending on your drain. So if you have a 3" drain (which you will need at least with a toilet), you can not just run a 1.5" vent out the roof. Hopefully someone here will be able to set me straight on this, or i'll post the chart when I get home.
Venting question Sammy 2 Plumbing 2 02-14-2011 08:57 PM
Question about dryer venting jimithing78 HVAC 10 08-26-2008 11:37 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
Rheem classic 90 plus venting question jjconst07 HVAC 2 07-04-2008 05:14 PM
venting question any pros? THEBIGPUNN Roofing/Siding 3 02-06-2006 08:19 PM
