Venting Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-01-2013, 11:54 AM   #1
Rewards Points: 396
venting question
A plumber told me this and I have no clue what there talking about. Is this accurate or not:
If the tee or wye used in venting is installed vertically, then the fitting is installed upside down, so that the 90 or 45 used is pointing down.
detroittigerfan is offline   Reply With Quote
Old 09-01-2013, 12:16 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 348
when connecting vents, the tee or wye is installed "upside down"
I don't understand your 90 and 45 comment though
Old 09-01-2013, 12:46 PM   #3
Rewards Points: 396
what do you mean installed upside down? I keep looking online and see nothing about it being installed upside down?
Old 09-01-2013, 01:13 PM   #4
Plumber
Rewards Points: 348
I assumed you knew since you referenced it in your OP-
Think like water- When water drains down from the roof vent, it needs to flow to the drain line it vents. Drainage fittings are shaped to allow this. Thats when you put a tee upside down.
Old 09-01-2013, 01:29 PM   #5
Rewards Points: 396
You mean a WYE?
Old 09-01-2013, 01:40 PM   #6
Rewards Points: 1,690
Rain water and condensate in a vent must be self draining. That way in areas that have winters an ice plug is not formed in the vent. I hope that will assist your question.
Old 09-01-2013, 02:01 PM   #7
Rewards Points: 396
When you have a wye or tee for venting don't you want the bend facing the direction of air movement?
Old 09-01-2013, 02:06 PM   #8
If your Wye or tee is vent only the rain and condensate flows downward towards your basement. So you would set the fittings to help that flow. If you are picking up a drain trap and use a y 45 fitting to do it in a vertical position it would place your trap above the vent and possibly be turned down. But that would be a drain vent application.
Old 09-01-2013, 04:14 PM   #9
Plumber
Rewards Points: 348
You mean a WYE?
No, I don't-wye's or tees can be used.
I don't think we are talking about the same thing or the same portion of the vent system.
You have a thread running here too drain question
I'm guessing these threads are related- can you just upload a picture of what your working on?
Another Venting Question rpratt84 Roofing/Siding 3 07-12-2012 04:17 PM
Dryer Venting Question jabond Appliances 2 06-21-2012 04:08 PM
Venting question Sammy 2 Plumbing 2 02-14-2011 09:57 PM
Question about dryer venting jimithing78 HVAC 10 08-26-2008 12:37 PM
Rheem classic 90 plus venting question jjconst07 HVAC 2 07-04-2008 06:14 PM
