Venting Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-23-2013, 02:49 PM   #16
Originally Posted by TheEplumber View Post
In the basement you should have a waste stack serving 1st floor fixtures and a vent stack venting the basement fixtures- that is a common vent- it serves 2 or more fixtures.
Tie into the common vent or make one if you don't have any plumbing there yet.
Do not vent into a waste stack- vent stacks only
Where I get confused is that I know you can wet vent fixtures that are on the same floor but lets say I added a shower in the basement wouldn't I have to extend the vent pipe up and over the first floor fixtures and tie into the stack to avoid the wet venting?
miguel24932 is offline   Reply With Quote
Old 03-24-2013, 04:31 PM   #17
If the fixtures are stacked then revent. Or separate if its not practical. You are asking a question that has no definite answer.
I read the article on circuit vents but am still confused. What exactly is that? Does that mean the drains for the fixtures run horizontally and eventually drain into the vertical main waste stack? And a separate vent stack is used for these fixtures?
Another Venting Question rpratt84 Roofing/Siding 3 07-12-2012 04:17 PM
Dryer Venting Question jabond Appliances 2 06-21-2012 04:08 PM
Venting question Sammy 2 Plumbing 2 02-14-2011 09:57 PM
Question about dryer venting jimithing78 HVAC 10 08-26-2008 12:37 PM
Rheem classic 90 plus venting question jjconst07 HVAC 2 07-04-2008 06:14 PM
