Old 01-22-2013, 12:00 AM   #1
Venting question
If you have a single story house can all the fixtures on the first floor be wet vented or be tied into the main stack at the same stack location? Reason I ask is because my first floor tub runs into the main stack which is only about 2 feet away so that stack also serves as its vent. The sink and toilet on that same floor are vented through that stack but higher up on the stack.
mikem201 is offline   Reply With Quote
Old 01-22-2013, 08:24 AM   #2
Master Plumber
Javiles's Avatar
Venting question
Yes common combination especially on older homes.
Experience is Knowing what to do next, Skill is knowing how to do it
Javiles is online now   Reply With Quote
Old 01-22-2013, 10:06 AM   #3
Doing it myself
Alan's Avatar
Venting question
UPC rules that only 1 and 2 fixture unit fixtures may be wet vented, and are limited to vertical drainage only.
Without seeing the way yours is plumbed, it's hard to say if it's proper according to UPC.
A location would give us an idea what code you are under. Different location = different code.
Journeyman Plumber
Another Venting Question rpratt84 Roofing 3 07-12-2012 04:17 PM
Dryer Venting Question jabond Appliances 2 06-21-2012 04:08 PM
Venting question Sammy 2 Plumbing 2 02-14-2011 09:57 PM
Question about dryer venting jimithing78 HVAC 10 08-26-2008 12:37 PM
Rheem classic 90 plus venting question jjconst07 HVAC 2 07-04-2008 06:14 PM
