#16 |
retired elect/hvac/plumb
Venting Question!
between 1 and 2,depending on who you ask
![]() Soap from washer drain will back up into the sink |
#17 | |
call me E
Venting Question!Quote:
and that pic is legit under all 5 adoptions in my area. I remember that thread with the picture, suds relief was well debated, rinse and repeat.........
#18 |
Venting Question!
You're saying between the two San-Ts picking up each branch drain(fitting #1 and #2) there should be 5'(5 feet) of separation?
Wouldn't that put the laundry sink at or close to the ceiling??? ![]()
#19 | |
Doing it myself
I've never had anyone complain about suds backing up into their sink, but then again, we have harder water here than most places. No need really for that nonsense.
Journeyman Plumber |
#20 | |
call me E
Running plumbing for utility sink |
#21 |
Venting Question!
Thats why i say the washer is supposed to run independently to a 3" line with nothing else tied into it,around here anyway.
I cant tell from the picture if the stack is 3" or not,but lets just say its 2" to make it easy. I would have run the washer drain under the floor to a wye cut into the nearest 3-4" line then by the time it got back to the sink tie in you would have over 5' between the 2 fittings and it wouldnt be an issue. I got nailed in omaha years ago on a floor drain being roughed in less than 5' from where the wye for the washer tied in to the main,I never did it again after that.
#22 | |
call me E
#23 |
Venting Question!
I looked up the article in the 2010 city of omaha plumbing code .
Article 49-605b says washer must run independently to a 3" line and must be plumbed a minimum of 5' from nearest tie in to a wc,which depending on your inspector whos neighborhood you happen to be working in can be interpreted as basically any opening in a pipe. It also says an existing 2" pipe can be used on a remodel if the chief inspector oks it,which basically means if either of his kids (who both own plumbing shops in omaha) need to use an existing pipe its ok the rest of us are just screwed!
#24 |
Venting Question!
OK Plummen I think I see where you're coming from...so you're saying the reasoning for the separation is for "suds pressure zones"
#25 |
Venting Question!
Yes ,thats the reasoning they use around omaha anyway.
Around louisville on the other hand you usually have to check the inspectors pulse to make sure hes breathing! ![]() Hey I just realized its been over 24 hrs since ive been called a hack and had anybody want to toss me off the site,what gives here? Last edited by plummen; 01-27-2012 at 12:16 AM. |
| Tags |
downstream, laundry, upstream, vent ![]() |
| Display Modes | |
| Venting question | Sammy 2 | Plumbing | 2 | 02-14-2011 09:57 PM |
| Question about dryer venting | jimithing78 | HVAC | 10 | 08-26-2008 12:37 PM |
| Rheem classic 90 plus venting question | jjconst07 | HVAC | 2 | 07-04-2008 06:14 PM |
| venting question any pros? | THEBIGPUNN | Roofing/Siding | 3 | 02-06-2006 09:19 PM |
