Venting Power Vent Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-07-2013, 08:49 PM   #1
Venting power vent water heater
I was wondering if anyone had experience with running the PVC pipe for a power vented water heater? Currently I have an electric water heater and I will be doing some first floor renovations to expose the studs in a wall directly above the water heater. I will be replacing the electric water with a natural gas unit. I want to know if I can run the PVC vent pipe inside the wall and have it stub into my attached garage rafters and through the roof?
Any help would be greatly appreciated.
Thanks!
RFW
RFWWorker is offline   Reply With Quote
Old 02-07-2013, 09:31 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 452
Venting for these units specified in their installation/owners manuals. u can find PDF files at their websites. They all have different specs.
Old 02-08-2013, 07:52 AM   #3
Master Plumber
Javiles's Avatar
Rewards Points: 990
Thanks!
RFW
To be specific NO
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 02-08-2013, 08:43 AM   #4
Originally Posted by Javiles View Post
To be specific NO
I'm assuming you're saying "no" to the part where I run the PVC pipe inside the wall. Is there a reason that you can share with me? Will the pipe get too hot even though it is power vented? The water heater would be a high efficient type. The manufacturer manual doesn't say you can or cannot run the pipe inside a wall. It does say it can be ran through a wall and through a roof.
Thanks.
RFW
Old 02-08-2013, 07:14 PM   #5
Master Plumber
Javiles's Avatar
Rewards Points: 990
Thanks.
RFW
Anywhere there is a potential fire hazard you can not have PVC its petroleum based and even if it did not burn through if it got hot enough it would emit toxic fumes. that why in certain buildings you can not use pvc for water or drainage must be in good ole cast iron and copper. national fire code. they make specific pipe for what you want to do.
Old 02-08-2013, 08:13 PM   #6
Plumber
Rewards Points: 452
Thanks!
RFW
I'd say you're penetrating a fire wall- thats a no-no without an approved method
Old 02-12-2013, 09:21 AM   #7
Thanks for taking the time to help me out with this. I'm still a little confused about what you're saying. Are you saying that using PVC is the issue here, or penetrating a fire-wall with PVC is the issue? If the latter is the concern, you're saying I could run the vent pipe inside the wall but not with PVC. Only with an approved type of pipe?
I'd like to add that I have a sewer vent stack going into my garage and through the garage roof. I was planning on running the water heater vent the same way. This vent wall installed when the house was initially built back in 1975.
Thanks,
RFW
Old 02-12-2013, 10:48 AM   #8
Plumber
Rewards Points: 452
Contact the manufacturers rep. On a proper install you are limited on length and fittings
Old 02-12-2013, 11:11 AM   #9
I do understand the length and fitting restrictions. I was just concerned about the vent pipe with exhaust being inside a wall for an 8 foot run, then you guys brought up the issue with penetrating a fire-wall that I didn't think of. I admit this is an unusual circumstance. I will contact the manufacturer to see what they say and report back what I find out.
Thanks.
RFW
Pipe vibration from power vent water heater cerfsud Plumbing 4 01-10-2012 07:39 PM
How can I tell if I need a power vent water heater? ... speedmaster Plumbing 2 11-01-2011 11:37 AM
Solar "Batch" Hot Water Heater, Help Please Ralph III Green Home Improvement 1 10-29-2011 10:12 PM
Water Heater blowing out Power to Entire House tbigley Electrical 5 03-02-2011 03:54 PM
Water Heater Vent problems hobber HVAC 5 02-01-2011 09:03 AM
