Venting Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-22-2009, 03:51 PM   #1
Venting pipe
I am trying to find the easiest way to vent bathroom fixtures. There is a 1 1/2" pipe coming from the cement in the basement. Can I use this as a vent pipe by connecting to the elbow with a T section pipe?
I have attached some pictures
Venting pipe-p5200027.jpg   Venting pipe-p5220029.jpg   Venting pipe-p5220030.jpg
james739 is offline   Reply With Quote
Old 05-22-2009, 09:05 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
I would say that the 1 1/2 is a vent/wet vent already. Are you planning to tie the fixtures into this pipe?
Old 05-22-2009, 09:57 PM   #3
Yes, the plan is to tie into it for my basement bathroom renovation. How do you know it is a wet vent?
Thanks you!
Old 05-22-2009, 09:59 PM   #4
Rewards Points: 560
Just speculating on wet vent.
What all are you going to tie in to this 1 1/2
Old 05-22-2009, 10:22 PM   #5
I am looking to tie the vent for the sink, shower and toilet. How can I be sure it is the correct vent?
Old 05-22-2009, 10:36 PM   #6
Rewards Points: 560
I am 99.9% sure that the 1 1/2 off the double Y with the two clean outs is a vent.
Are you going to bust out concrete to tie in on the 3" or 4" line.
Keep in mind that the toilet needs to be 3" or 4", shower drain with trap 2" and lavatory 1 1/2"
Old 05-22-2009, 10:59 PM   #7
I will be concrete in the laundry room. That is where the lavatory is going. The waste stack in the picture is right below my power room. I will have to cut through the concrete to connect to it.
The Vent that I was referring to earlier is not in the same room (laundry room) it is 16 feet away in a small closet.
I want to avoid as much damage as possible since the basement is already finished. That is why I want to confirm if it is up to code to connect to that vent from the laundry room
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 01:20 PM
Septic/sewer pipe replacement Mendocino Plumbing 4 11-21-2008 06:40 PM
First Furnace Install - Need Some Help Getting Started hartkem HVAC 17 10-11-2008 12:55 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 12:09 PM
