Venting My Home - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-16-2011, 09:57 PM   #1
Venting my home
Building a new three story house. Four inch pipe coming up through the floor in basement, after i tie in all my fixtures to this four inch pipe can I reduce it to two inch and carry it out through the roof as a vet stack?
Westwing is offline   Reply With Quote
Old 11-17-2011, 12:25 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 818
Codes differ in different regions. I need the combined cross sectional area of all my vents to equal the cross sectional area of my building drain. So if your taking a 4" drain out of the house you need the equivalent of 4" through the roof. This may be achieved with multiple vent pipes. Such as 4- 2" vents.
Also, vents are sized by the fixtures they serve. I doubt you could put a 3 story house on a 2" vent.
Old 11-17-2011, 07:43 AM   #3
Rewards Points: 3,130
Depends on code where you live. I could not do it but maybe you can.
Old 11-17-2011, 10:06 AM   #4
Rewards Points: 2,240
Is the vent pipe PVC, copper, cast iron -
What's the apprx. outside, width of the pipe?
rossfingal
rossfingal is offline   Reply With Quote
Old 11-17-2011, 08:17 PM   #5
Rewards Points: 582
I would not reduce vent .....as eplumber said it size is based on fixture units that it supplies and a 2" vent would only supply as a releif vent for one water closet...you know commode.....most codes don't allow reducing stack must go same size through roof...Ben
Need home plans for a simple barn home! RUMBLON General DIY Discussions 0 06-02-2011 03:05 PM
NEWBIE- Looking to build my own Barn Home in Idaho LAWFISH General DIY Discussions 2 11-14-2008 07:43 PM
Owning a home (not a mobile home) on leased land? Badfish740 Off Topic 11 03-30-2008 09:34 AM
