Venting Kitchen Sink Under Window In California - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-05-2012, 11:04 PM   #1
Thadius856's Avatar
Rewards Points: 504
Venting Kitchen Sink Under Window in California
Hi all! I'm realatively new to plumbing, and having a little trouble with fixing the existing hack job that I just found when I removed my sink to insulate an exterior wall.
Here's what I'm working with. One king and two cripples notched down to only 20% left on the backside. 36" window above a 34" sink in a 36" cabinet.
Code seems to prevent mechanically reinforcing with steel plate or moving the vent T below the floor ("wet"). Found this explanation on another site, but can't get my head around it. Does anybody have a diagram that might help me visualize it?
Originally Posted by packy on plbg
you can run the drain up into the wall cavity beside the window. put a sanitary tee in that drain at 13" above the floor. continue the top of the san tee up thru the roof or into another vent stack in the attic.
turn the branch of the san tee at a 45deg facing into the kitchen. put a street 45 into the branch of the san tee and run a horizontal drain 3 feet to near the center of the window. this drain will set on the surface of the 2 x 4's and you will have to knotch the back of the cabinet to install it.
Check out my on-going Project Thread!
Current Project: Whole House Data Wiring
Back Burner: Drywall Patching
Planning: Kitchen Reno
Thadius856 is offline   Reply With Quote
Old 08-06-2012, 11:21 PM   #2
Thadius856's Avatar
Rewards Points: 504
*bump*
Old 08-07-2012, 12:25 AM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Your other option is to stub out through the drywall in both stud cavities, then install cabinets, and drill and connect piping as needed in the back of cabinets. More than likely going to need piping graded at 1/4" per foot in cabinets. . . . .
Oregon plumbing code allows us to be as high as possible under structural conditions and then use drainage fittings if we are less than 6" above the flood level rim. Be sure there isn't a provision like this in CA code.
Journeyman Plumber
Why does my Kitchen Sink Smell? Syz Plumbing 10 10-30-2011 11:13 PM
Mysterious Smell Under Kitchen Sink jimmycrackcode General DIY Discussions 6 10-22-2011 12:43 AM
Double Bowl Kitchen Sink Drainage Problem PeteW Plumbing 16 09-05-2011 10:41 AM
Kitchen sink centered on cabinet? sillyboy22 Plumbing 3 03-02-2010 10:16 PM
temporary set up in utility room for kitchen renovation (sink; dishwasher) ilyaz Plumbing 3 01-25-2010 07:07 PM
