Venting Kitchen Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-16-2012, 09:14 PM   #1
I am remodeling a 1875, one story home with an unfinished basement. After removing all plumbing and finding no vent system in the kitchen, I need help to determine the best way to vent and drain a double kitchen sink with disposal and dishwasher. The main stack is 14' away. The old 24" limestone foundation restricts me from putting the drain through the wall with vent and a p-trap under counter. A floor drain I assume will be my only option here. The vent for the sink I will be able to put into the wall, through the attic, and attach into the main vent.
What is the best way for me to vent and drain the above described scenario? I would prefer to avoid using a S-trap(issues with being sucked dry) or an AAV or similar type.
Thank you for your help.
TraverseJA is offline   Reply With Quote
Old 07-16-2012, 10:17 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 772
Bring the vertical 2" pipe through the floor near the outside wall. Immediately, offset it into the wall and plumb it as normal from that point on. If done properly, it won't interfere with the cabinets. The waters can come up through the base.
The Following User Says Thank You to TheEplumber For This Useful Post:
TraverseJA (07-17-2012)
Tags
dwv , kitchen sink
kitchen revamped, help with sink drain plumbing rfire15 Plumbing 6 09-29-2011 08:45 PM
Smell Under Kitchen Sink mamaerin General DIY Discussions 4 09-23-2009 11:01 AM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 05:41 PM
vent stack for kitchen sink Knucklez Plumbing 4 04-02-2008 06:49 PM
Sink or No Sink in Kitchen Island? Not Sure Plumbing 4 08-29-2006 07:37 PM
