Venting Inadequate With AAV Kitchen Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-31-2012, 10:21 AM   #1
Venting inadequate with AAV Kitchen sink
I have a Venting problem but I don’t know why.
This is a completely new installation. Pictures & diagram attached
2nd kitchen – 2nd floor only one kitchen per floor
Sink drains very slow – several minutes if both sinks are half filled or one is block at strainer while other is draining.
If one sink is filled to near top and other sink is open- will drain most of the way then water comes up into empty sink and slow to drain the rest of the way for both.
if remove Studor Mini-Vent DMV AAV– water rushes down however water is present at Studor Mini-Vent DMV AAV also.
have experimented with different brand and style undersink vents.
Pictures show other vent, however now installed & using Studor Mini-Vent DMV AAV
ALL DW piping has a Ό” per foot pitch.
Center (between bowl) T has a deflector
T below Studor AAV is a sweep not a straight T
All piping is new from sink to 2” roof vent 15’ away.
Nothing else taps into this vent all the way to 3” horizontal in basement
Undersink is 1 ½” until just before T .
Undersink T until Roof vent is 1 ½” SCH 40
Undersink T till undersink Studor AAV is 1 /12” SCH 40
This is all on a septic not public sewage.
Double bowl SS sink is 33” X 22” total X 6” deep.
Kitchen is 2nd floor residential.
Height of top of vent above roof approx. 18” above top of sink.
· Will vent up to 160 DFUs on a branch
· Will vent up to 24 DFUs on stack
Not being inspected. Looking for safe and functional.
Advice please
Pic 1
Pic 2:
DownStream is offline   Reply With Quote
Old 07-31-2012, 11:57 AM   #2
Rewards Points: 3,130
Well, I don't know why either. Your setup looks very much like what I did with my kitchen sink and mine drains just fine. It almost sounds like you have a blockage somewhere.
aav , kitchen plumbing , slow drain , studor mini vent , venting
Why does my Kitchen Sink Smell? Syz Plumbing 10 10-30-2011 10:13 PM
kitchen revamped, help with sink drain plumbing rfire15 Plumbing 6 09-29-2011 08:45 PM
Need help re-routing kitchen sink vent Fingers Plumbing 11 10-23-2009 03:17 PM
Smell Under Kitchen Sink mamaerin General DIY Discussions 4 09-23-2009 11:01 AM
vent stack for kitchen sink Knucklez Plumbing 4 04-02-2008 06:49 PM
