Venting Basement Washroom - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-16-2010, 12:22 PM   #1
Rewards Points: 51
Venting basement washroom
Hi,.
I'm installing a Saniflow pumping toilet in the basement of my two storey home. I will also be connecting a bath tub and vanity sink to this pumping toilet. Can I vent this system through a vent connected to a vanity sink on the first floor?? I would be connecting to the vent at a level above the first floor sink's trap.
deepstuff is offline   Reply With Quote
Old 06-16-2010, 01:31 PM   #2
Originally Posted by deepstuff View Post
Hi,.
Yes, you can connect the saniflow system into the regular venting system. BUT! I want to point out that you should connect into the existing vent 6 inches above the flood rim of the sink upstairs. (6" above the countertop) If you connect in below the sink, but above the trap, and if there is a clog in your waste line from the sink, the water will back up and flow down the vent line into your basement system.
The Engineer is offline   Reply With Quote
Old 06-17-2010, 08:37 PM   #3
Rewards Points: 51
Question
Not sure if I can get to 6-inches above counter top but should be able to get close to counter top level. I has you say it ever got plugged wouldn't that keep water in the sink to indicate a plug before I totally flooded my basement?
Old 06-18-2010, 07:41 AM   #4
As long as you get the vent as high to the underside of the counter as possible, the system will work as it should and your sink won't drain down the vent as long as the water is not up to the rim of the sink. Just remember that it will not be code complaint if you try to sell your house down the road and the inspector see's it that way.
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 08:40 AM
Ugly Cold Floor in Basement Washroom Makes Wife Grumpy slydevil Flooring 7 02-11-2010 09:10 AM
Venting of basement plumbing fixtures david.plymouth Plumbing 3 01-18-2010 06:46 PM
Venting basement bathroom fixtures ccathy247 Plumbing 1 11-01-2008 04:44 PM
Removing basement washroom rough-in Cark99 Plumbing 2 10-07-2007 03:50 PM
