Venting Basement Bathroom With Lift Station. - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-04-2012, 09:58 PM   #1
Venting basement bathroom with lift station.
I have a roughed in basement bathroom. The shower, toilet, and sink all drain into a sealed lift station. All drains are pretty close to the lift station. Toilet 2 feet, shower 3 feet, and sink drain about 8 feet. What would be required as far as venting. There is currently a 2 inch vent coming out of the top of the lift station that I would assume goes all the way to the roof.
jamesdinger is offline   Reply With Quote
Old 05-04-2012, 10:40 PM   #2
Rewards Points: 636
without seeing it, i would say if anything the sink maybe or the use of a.a.v.
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 05-04-2012, 10:42 PM   #3
It sounds like your vent is off the lift. It probably ties in to another vent before going through the roof.
sanec1 is offline   Reply With Quote
Old 05-04-2012, 10:46 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 452
Typically, you vent it with a 2" vent through the roof on a dedicated vent. If not possible- tie it into another properly sized vent. Do not use a AAV as they are a directional, one way type of vent. A sump needs to draw air as well as displace air.
Old 05-05-2012, 11:17 AM   #5
They stubbed a 2" vent off the shower drain that comes up through the concrete. The only existing vent to the roof is the 2" that comes out of the lift station. I don't suppose using that is an option or is it? Example tie the existing shower vent into this lift station vent. Then also T off behind the vanity and run a vent up from there also to tie into the lift station vent.
Old 05-05-2012, 11:45 AM   #6
Rewards Points: 636
yes all vents can be tied together
Old 05-05-2012, 11:50 AM   #7
Experienced
Jackofall1's Avatar
As long as the point at which you tie into has no drains above it, if so, the tie-in point would have to be above the flood plain of the fixture being drained.
Mark
The Following User Says Thank You to Jackofall1 For This Useful Post:
jaydevries (05-05-2012)
Question about Plumbing Basement bathroom with PEX dgreen Plumbing 5 03-08-2012 04:28 PM
bathroom subfloor (Basement) BlueBSH Building & Construction 27 12-02-2011 11:10 AM
multiple choice - basement bathroom venting debacle and burps denemante Plumbing 1 11-15-2011 11:50 AM
Plumbing Help for New Basement Bathroom morphers82 Plumbing 2 03-14-2009 01:17 AM
basement bathroom rough in - framing questions twobabieslater Building & Construction 2 12-29-2008 03:56 PM
