Old 01-16-2009, 02:41 PM   #16
WaldenL's Avatar
Dumb question here... Any reason the OP couldn't just vent the kitchen sink out the sidewall by the sink? (Might be aesthetic reasons, I'm looking for a plumbing one) Must the vent go vertically through the roof? I don't see why.
WaldenL is offline   Reply With Quote
Old 01-16-2009, 03:38 PM   #17
The vent is on the drain side of the trap so it would let out any/all sewer gases which i don't think anyone would want to walk by their house and smell sewer gases or open the window and have the house smell like a sewer.
ponch37300 is offline   Reply With Quote
Old 01-16-2009, 05:10 PM   #18
Originally Posted by Nestor_Kelebay View Post
Your drawing shows a 22 1/2 degree elbow on a 1 1/2 inch drain line.
I understand that you might need a 45 to get the vent vertical. My point is that I've never seen a 22 1/2 degree elbow in the smaller plastic pipe sizes like 1 1/2 inch. Do they exist?
Look again Nestor, it takes a 180 degrees to reverse direction. There's one 90 at the the top, so the other two must be 45's!
Old 01-16-2009, 05:16 PM   #19
Originally Posted by ponch37300 View Post
Thanks for all the help guys. I think i understand most of it now. I made a little drawing(I'm definitely not an artist!) of a two story house with a toilet on each level by the main stack. Then the kitchen sink on the other side. When i vent the kitchen sink can i tie into the main stack in between the 1st floor and 2nd floor or is this considered wet venting and not good? Should i just run the sink vent up to the attic and tie into the main stack above all the drains? Also if i have a sink in the 1st floor bathroom how would i vent that? Can i tie it into the main stack on the 1st floor or would this also be wet venting? Or do i have to run this all the way up to the attic and tie into the main stack above the drains for the 2nd floor fixtures? Thanks again for your knowledge
A vent should not connect to the main stack, where excrement passes by! Some will find its way into the vent and eventually the vent will plug!
Old 01-16-2009, 06:15 PM   #20
Thanks wildie..Is that considered wet venting? So my best option would be to run the vent to the attic and then tie into the main stack or use a mechanical vent?
Old 01-16-2009, 06:40 PM   #21
Yes! annnd Yes! I have used mechanical venting, and they work well also!
Old 01-16-2009, 07:56 PM   #22
Thanks everyone. Think i have a good grasp on this venting stuff!
More On This Topic
We are going to talk a little bit about our waste lines and our vent lines right now. The waste line being when you turn the sink on and the water that falls into the sink, where does it go, well it goes right down into this pipe here, travels down the... Read More »
Bathroom Design Ideas
Bathroom Design Ideas by Expert Village
When I met with the homeowner he told me where he wanted to build his new bathroom and what he wanted to have in it and where he wanted to have it. Originally he wanted the toilet where I am standing and I told him I thought it would be better in the... Read More »
We are going to talk a little bit about the toilet flange here and this is where your toilet will sit. This is a 3 inch toilet flange and it ties down into our main 3 inch AVS sewer line and again we have that 1/8 inch fall per foot so that the solids... Read More »
We are doing a kitchen remodel, and we’re installing the sink. We have replaced one of the supply lines, we have the sink in, and the supply line is connected to the outlet valves. Now we’re going to install a dishwasher drain. You put it on... Read More »
Hi this is Jon on behalf of Expert Village in this video clip I will be taking you through step one in making a sink drain better. The first thing we need to do is identify the problem when this sink fills up the water takes a very long time to drain out... Read More »
venting metal roof for attic conversion nelsonC Roofing 13 01-29-2009 09:05 AM
Addition Question: venting roof/crawlspace supton Building & Construction 6 01-22-2009 08:33 PM
repair furnace venting diybrian HVAC 2 12-29-2008 09:56 AM
Blocked Attic Soffit Vents on North Side - How to Improve Venting Jes Roofing 5 05-06-2008 11:35 AM
Furnace venting questions Mastiff HVAC 4 02-15-2007 09:27 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
