Venting A 2 Story House - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-24-2013, 04:09 PM   #1
venting a 2 story house
When you vent the fixtures on the 2nd floor of a 2 story house do they need to have there own stack or is it more common to re-vent the first story fixtures up and over the 2nd story fixtures so as to avoid wet venting.
mikem201 is offline   Reply With Quote
Old 01-24-2013, 04:19 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 912
Either way works. The decision is made in the field based on practicality.
Just be sure your tie ins are 6" above the flood rim of the fixtures- 42" is a "good rule of thumb".
Old 01-24-2013, 04:22 PM   #3
When you run a secondary stack just for 2nd floor does it also need to be 3"? And should it run from the roof to the basement and then tie into the main stack from underground?
Old 01-24-2013, 04:41 PM   #4
Plumber
Rewards Points: 912
Questions like this sort of depends on your local code. For starters- you need the combined equivalent of the area of a 4" vent. if you're doing an addition/remodel you probably have an existing 4" vent stack- so you can vent your new fixtures based on their required vent size- a bathroom usually needs a 2"
You don't need to vent to the basement when the fixture is on the second floor.
You mind telling us where you are? It helps with code stuff
Old 01-24-2013, 04:43 PM   #5
Ok what im asking is for second floor fixtures that need their own stack. Should that new stack that runs to the roof be only for venting or should it also be a waste stack that eventually ties into the main stack in the basement? These are just things im asking for an understanding.
Old 01-24-2013, 04:54 PM   #6
Plumber
Rewards Points: 912
The pipe through the roof is a vent stack. The pipe through the floor is a waste/drain stack. The waste stack can tie into another drain line or stack as long as it is sized correctly. It does not have to go under slab.
Can you upload a picture of your project? You'll get specific answers that way and we won't have to try and second guess your plans.
Old 01-24-2013, 05:23 PM   #7
Its not a project just curiosity. I understand the top of the stack serves as a vent and the bottom is waste but what im asking is for running a separate stack for a second floor does the stack need to go through the roof and back to the basement and then tie into the MAIN stack or can the second story fixtures just have a separate vent stack through the roof but can drain into the main stack?
House on Crawl Space - Sagging Center Beam - Need Advise stevenrossi Building & Construction 9 01-17-2017 10:32 AM
Whole house fan and venting cww1 Roofing/Siding 0 11-21-2012 04:24 PM
Need help with attic venting on old house danstar25 Roofing/Siding 7 06-24-2012 10:01 AM
installing whole house filter on outside of house MikeInFL Plumbing 3 06-12-2010 04:47 PM
venting a pool house and trying to aviod ridge vent meepslala Roofing/Siding 2 05-06-2010 08:23 PM
