#1 |
Ventilation
I have a sewer (septic tank) gas problem. When a toilet is set you can see the water inside the bowl moving; it is like a blower motor inside the lines. Take up the toilet and the pressure coming out of the pipes is so much you can't stop it. Usually you can stuff a rag in the flange but not this one. The home I bought is in SW Florida Everglades where it is hot and humid. Why is that pressure so strong in those pipes? I had the septic tank serviced and can smell that perfume those guys put in it. Any ideas?
I can set a toilet and 4, 5 6 days later the wax ring is melting from all that warm humid air running through the pipes. I had the pipes cameraed and wasd told the pipes are fine. The roof vents are right beside the fart fan vents, and the lead around those vents is damaged but that PRESSURE is stronger than any open sewer line you have ever seen.
#2 |
Ventilation
i would start by looking into venting
be careful my advice only comes from general knowledge i know about the 4 rules it takes to plumb and they are 1 poop needs to flow down hill. 2 hot on left cold on right 3 i get a pay check on Mondays 4 do not chew finger nails at or after work. |
#3 |
Ventilation
is the house plumbing vented correctly
be careful my advice only comes from general knowledge i know about the 4 rules it takes to plumb and they are 1 poop needs to flow down hill. 2 hot on left cold on right 3 i get a pay check on Mondays 4 do not chew finger nails at or after work. Last edited by jaydevries; 08-11-2012 at 12:32 PM. |
#4 |
Ventilation |
#5 |
call me E
Ventilation
Sounds like a lot of pressure. Did any one tie your water heater or furnace venting into your plumbing?
When posting in forums, letting us know your location will help others give better feedback/advice/solutions to your questions |
| The Following User Says Thank You to TheEplumber For This Useful Post: | jaydevries (08-11-2012) |
#6 |
Ventilation
to add to that thought exhaust fan
#7 |
Ventilation
Could be; I can plug off the 4 inch line at the septic tank and come back later to take out the test ball and water behind the test ball or with no water running at all, I can see water coming into the clean-out before the septic tank. I tried Studor vents up top on the vent stacks but that makes it unbearable inside. I can put a test ball in the clean out right next to the septic tank and still get sewer gas at the toilet. Just too much pressure for a wax ring to hold up. I tried using plumber's putty under the flange next to the concrete but it melts too. Too much pressure.
#8 | |
call me E
VentilationQuote:
#9 |
Ventilation
Water heater is electric, furnace is a package heat pump/ac. Neither is vented that I know of. You can go to the job site and put a rag into a flange or wall stub but not mine; like I said it is like a small blower motor pushing air through there. The camera didn't show any holes/roots in the lines.
#10 | |
call me E
VentilationQuote:
| Display Modes | |
| Attic ventilation and Whole House fan | cp31817 | Roofing/Siding | 8 | 05-02-2012 08:55 PM |
| Ventilation - Opposing gable, limited soffit + box vents = Screwed up? | darlingm | Roofing/Siding | 1 | 09-07-2011 11:13 AM |
| Oh God.. no ventilation | MileHiBill | Roofing/Siding | 1 | 07-15-2011 05:02 PM |
| Honeywell Visionpro IAQ function 406 ventilation in high humidity ? | Charlie123 | HVAC | 1 | 05-08-2010 12:19 PM |
| Light, Ventilation, and Heating code requirements | sarbear | HVAC | 12 | 11-30-2009 12:10 PM |
