Ventalation Pipe Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-08-2010, 01:14 PM   #1
Ok so I am working on changing our washing machine drain method from in to our old sink to a Wall Receptacle with Brass 1/4 Turn faucets. I feel comfortable in my ability to run the pipes over however. As you will notice in the below picture I need to move the drain pipe up higher to get around an electrical outlet. My question is, is it safe to tie in to the Vent pipe you see in the picture about 2 feet up from the existing drain and remove the existing drain? if you don't understand what I mean please let me know and I will try to explain it better.
JordanB is offline   Reply With Quote
Old 12-08-2010, 05:51 PM   #2
Rewards Points: 150
Do you plan to use a wash machine in wall box?
Is that pipe 2in.?
Does the pipe going up have any fixtures connected to it?
Need the answers to give a good reply.
braindead is offline   Reply With Quote
Old 12-09-2010, 12:19 AM   #3
FTRR
The answer is yes, when you remove the old drain make sure your coupler is sealed well as water will be passing that point from your new elevated drain.
FamilyTreeRemod is offline   Reply With Quote
heat and gas pipe question? signal HVAC 1 09-22-2010 12:44 PM
Is yellow polyethelene or polyphenol gas pipe now the preferred gas conduit? MarkSilber Plumbing 1 09-18-2010 12:10 PM
Using sharkbite to fit leak in pipe...pipe hole size question. RyanD Plumbing 4 08-14-2009 06:17 PM
Reclaimed water pipe (Purple PVC) repair and glue question smcmurrey Plumbing 3 07-07-2008 09:49 PM
Vent Pipe Leak romeguy1 Plumbing 9 12-11-2005 12:08 AM
